TRD gearbox ?
04-06-2008, 05:52 PM
TRD gearbox ?
i have seen that TRD hat made an gearbox/gearset to the T50.
anyone there has tried it, an know what it helps . i hope you can help me. regards sonny why drive, when you can drift |
04-06-2008, 06:11 PM
TRD gearbox ?
looks like it has closer ratios than the standard gearset so ingear changes should keep you in the power band better,must admit im surprised to see no uprated synchros are supplied though,on a 20year old gearbox??
04-06-2008, 06:34 PM
TRD gearbox ?
Yes TRD does offer such kits.
They are quite expensive though. Quaife has some straight cut ones and you could also go sequential. There are some choices you can go but neither one will come cheap. I have all TRD charts available where you can see details on speed and gear. Cheapest version will be a ring and pinion and change the whole ratio with it. If you need further info let me know. Speed Industries Hurdnerwaeldlistr. 73 8808 Pfaeffikon Switzerland e-mail: [email protected] phone: +4155 420 15 69 page: http://www.speed-industries.ch MSN: [email protected] We have all the parts your Hachi needs |
04-06-2008, 07:47 PM
TRD gearbox ?
http://www.sg-rallyesport.de |
04-06-2008, 09:34 PM
TRD gearbox ?
okay, thanks for the help.
what does such and trd kit cost? i want to use the car for drifting, will this helps the car, og dosent it matters,, the car will have about 200 hp maybe a bit more, and wil run whit 15´wheels i think.. i have also heard that there are different ring og pinion gearratios. have you and idea too an god setup for gearing and that sort of stuf regards sonny why drive, when you can drift |
04-06-2008, 09:47 PM
TRD gearbox ?
I guess if you buy the kit and built the transmission with new bearings, synchros etc., it will cost you about 3000,-€.
Like koh already said it keeps you better in power band, but you need a shorter ring and pinion. I don´t think it´s very necessary for drifting, cause in a long drift the possibility you need to shift is bigger. It´s good for a better acceleration in races... Greets raki http://www.sg-rallyesport.de |
04-07-2008, 05:52 AM
TRD gearbox ?
I have the 3 speed TRD box with a 4.778 final drive. Works very well. 1st is higher than std, 2nd slightly higher, 3rd lower than std. 4th & 5th are std. ratios, but the lower final also makes these shorter. Use brand new Toyota original synchromesh, bearings, seals, etc. when rebuilding.
It's a very worthwhile modification especially if you have a high reving peaky tuned engine. It is better for drifting too, especially the higher 2nd and closer 3rd - as it'll help keep you in the powerband longer. We supply these too of course! Can get a box built here in Japan then shipped. Techno Pro Spirits did mine. It's perfect. VISIT OUR NEW WEBSITES!!!! A Tuner's Paradise Automotive Art On Film Dedication To Automotive Perfection Japan Office Tel - (Calls charged at UK National Rate): 0207-193-3979. Mobile (Japan): +81- (0) 90-4133-3825 Fax (Japan): +81-(0) 47-307-4678 |
04-07-2008, 05:53 AM
TRD gearbox ?
Now, the TRD ratio sets are just close ratios, correct? No dog engagement?
Wow, I could have sworn I had an account here... I guess I'm the new guy ![]() |
04-07-2008, 09:46 AM
TRD gearbox ?
Quote:Now, the TRD ratio sets are just close ratios, correct? No dog engagement? Correct if you want a dog box , then Quaife make a t50 kit .It has a 5th gear of 1-1 (the same as your stantard Toyota t50 4th gear). I use a TRD close ratio kit in my Tarmac Rally car, it changes 1st,2nd,3rd, and 5th gear ratios http://www.aeu86.org/viewtopic/nzae86s--...t-1/t/6170 I also use a 4.8 ratio final drive with this kit, 1st gear is about the same as a standard t50 2nd gear |
04-07-2008, 11:52 AM
TRD gearbox ?
okay.
thanks for the answers . why drive, when you can drift |
weird gearbox part2(possible trd set a) | ditn | 6 | 7,366 |
01-31-2016 08:01 PM Last Post: totta Crolla |
T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 6,902 |
11-27-2015 10:06 AM Last Post: Project D |
TRD Gearbox problem | filh | 9 | 7,885 |
06-03-2009 11:30 AM Last Post: The Doctor |
