TVIS probloms
07-29-2008, 06:06 PM
TVIS probloms
Banging head HEy guys i don't kwon if my TVIS is working so i don't know how to test it i know that it works by vacumm Undecided (or am i worng..?) so if anybody can tell me how to test it to see if it's working
'85 Corolla Sprinter Trueno GT-APEX
07-30-2008, 08:12 AM
TVIS probloms
What are the symptoms? If the TVIS isn't working correctly you should have less torque in the lower rpms.
You can test it by revving it above 5000 rpm on the throttle and look around the vacuum canister under the TVIS: it should open (above 5000rpm) and close (under 5000 rpm) the butterflies when working correctly.
[Image: AEU86 AE86 - TVIS probloms]
07-30-2008, 03:42 PM
TVIS probloms
Well it's hard to rev it to 3000 RPM but after that the engine works good
08-01-2008, 06:03 AM
TVIS probloms
More info needed! What's hard about getting it to 3000rpm? Is it slow going, does it splutter (technical term Tongue )?
When you say it's good above 3000, do you mean runs normally, vibrations, noise, emissions?
08-10-2008, 12:36 AM
TVIS probloms
CoolinAE86 Wrote:Well it's hard to rev it to 3000 RPM but after that the engine works good
That isnt your TVIS.
What does your engine diagnosis tell you.
Ecu could be in limp home mode because of a simple sensor error or vacumm leak.
Could be a busted h/gasket aswell.
Steve.....this is sparrrrrtan
08-12-2008, 05:52 AM
TVIS probloms
Make sure that you're vacuum lines are connected right with the EVAP canister.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  Early tvis red top from e9 gti small or bigport? Ryo 3 8,872 04-20-2018 09:14 AM
  20v silvertop exhaust manifold on 16v 2nd version tvis motor Apsogos 17 26,127 11-22-2012 11:15 PM
Last Post: Apsogos
  my tvis doesnt work... daywalker 30 54,719 02-19-2012 01:25 PM
Last Post: ZDoman
  technical asking about TVIS filh 4 7,136 02-27-2011 02:07 AM
Last Post: filh
  TVIS close ignition switch??? juantonwan 2 4,322 07-27-2010 12:17 AM
Last Post: totta Crolla
