TVIS?
04-10-2007, 09:31 PM
Post: #41
TVIS?
i know that, but I found it weird that when I kept the revs just a little above 4k rpm and the t-vis all open, i could keep the car in the drift.
But 200 rpm's less and the t-vis 'closed' (16v/12v was easier to explane Tongue ) the car just lost power and rev's. So there has to be a significant diffrence in power at that rpm range with the t-vis on and with the t-vis off.
And I dont mind if the car is a bit slower at low revs. I'm using my car mostly in midrange and high revs.
No more Panda..
Tricolor bastard!
04-10-2007, 09:42 PM
Post: #42
TVIS?
Dennis, your going to fast there...
Don't forget that in 3rd gear, you'll have less power at the rear wheels.
I didn't change a single thing to my engine, but i did fitted a taller diff, and now it's just rubbish to drive, it's just slow Smile
04-10-2007, 09:54 PM
Post: #43
TVIS?
D.Wars, TVIS removal leads to ITB solutions Tongue
04-10-2007, 10:04 PM
Post: #44
TVIS?
that's another idea Cool
No more Panda..
Tricolor bastard!
04-11-2007, 08:29 AM
Post: #45
TVIS?
AFAIK the tvis opens at 4400-4500 rpm, but that might differ per ECU. But as said before: removing the tvis doesn't help too much. The ECU will still inject the same amount of fuel, so removing it would require remapping your ECU. But then you'd better go for the ITB. Wink
[Image: AEU86 AE86 - TVIS?]
04-17-2007, 09:27 PM
Post: #46
TVIS?
On the UK 4A-GE ECU for both AE86 and AW11 MR2, Toyota employ a little trick in the ECU program code to add some kick to the TVIS.
When the rpm exceeds the TVIS threshold the ECU starts a little delay counter. This counter adds a delay to allow the TVIS flaps to open, once the counter finishes the ECU suddenly adds 3 degrees of ignition advance to the timing!
This was maybe a marketing ploy to help sell the benefits of TVIS. i.e. some of the kick is really the sudden ignition timing change!
if you remove the TVIS mechanicals you will still get the 3 degree step in timing at the TVIS rpm.
It is actually quite annoying as this means the engine is starved of optimum ignition timing below the TVIS point (by maybe 3 degrees!)
Just to get that kick...
04-17-2007, 09:35 PM
Post: #47
TVIS?
Just a stupid side-thought... During the late 70s and early 80s turbo was a huge buzzword... Perhaps someone loved that kick enough to build something like that in the ECU? Big Grin
04-20-2007, 11:25 AM
Post: #48
TVIS?
The TVIS system increases the intake air velocity at low rpm's to
promote fuel vapourisation and cylinder turbulance. This gives
improved combustion, more torque and better low rpm acceleration.
After 4200 rpm the TVIS butterflys are open and the throttle area is
doubled for greater airflow at high rpm. But as can be seen from the
graphs, torque drops off at high rpm in a standard engine, meaning
that revving past 7000 rpm offers no performance advantage.. only fun Smile
For normal street driving the TVIS makes the car pull stronger out of
corners and generally nicer to drive. Disconnect the vacuum hose to
keep the TVIS permanently open and compare, before you decide to
remove the butterflys.
Cheers... jondee86
04-20-2007, 06:32 PM
Post: #49
TVIS?
It might have performance advantages when you want to hit your powerband on an upshift.
04-20-2007, 10:22 PM
Post: #50
TVIS?
Quote:It might have performance advantages when you want to hit your
Sure... especially from 3rd to 4th !! And having a few extra revs
to play with means you can often hold a gear between two corners,
rather than upshift then downshift.
Cheers... jondee86
  Early tvis red top from e9 gti small or bigport? Ryo 3 7,443 04-20-2018 09:14 AM
  20v silvertop exhaust manifold on 16v 2nd version tvis motor Apsogos 17 22,242 11-22-2012 11:15 PM
Last Post: Apsogos
  my tvis doesnt work... daywalker 30 47,298 02-19-2012 01:25 PM
Last Post: ZDoman
  technical asking about TVIS filh 4 6,019 02-27-2011 02:07 AM
Last Post: filh
  TVIS close ignition switch??? juantonwan 2 3,546 07-27-2010 12:17 AM
Last Post: totta Crolla
