Techno Toy Tuning 4 Link Kit
10-11-2007, 03:43 PM
Hi!
What do you think about the TTT 4 Link kit in combitnation with the Panhard / Lateral Bar?!
http://www.technotoytuning.com/productdetail.php?p=688
Is this good stuff?!
10-11-2007, 05:22 PM
Jup. But most of the 4 link kits out there are fine..T3 looks pretty though
10-11-2007, 06:01 PM
well very fine quality products with teflon coated bearings, but are you sure you need this set? for track use or good quality roads no problems but poor quality roads can twist you chassis, unibal bearings cannot absorb vibrations as rubber or polyurethane.
my idea is 4links on Pu or hard rubber and maybe unibal panhard rod for road use
http://www.86ers.org
10-11-2007, 07:18 PM
Thanks for your opinions.
Maybe I´ll buy the panhard rod from TTT and traction brackets and use the stock 4 link units with aftermarket bushings.....
10-11-2007, 07:51 PM
I have the T3 panhard rod in combination with the stock 4links on PU. I really like this setup and wouldnt think about buying the T3 4 links. Besides, I do recommend a T3 panhard rod because it takes away the wiggle of the rear when cornering on a rough road.
[Image: AEU86 AE86 - Techno Toy Tuning 4 Link Kit]
10-11-2007, 09:26 PM
Gabriel Tyler from TTT says, that they have 2 ae86 with this 4 link kit and they use their cars as daily drivers and doenst have any problems with this kit,....
10-11-2007, 10:30 PM
AshCampbell Wrote:Gabriel Tyler from TTT says, that they have 2 ae86 with this 4 link kit and they use their cars as daily drivers and doenst have any problems with this kit,....
yeah.. it shouldnt be a problem but I agree with Seki. Consider it carefully thinking about what roads you usually drive. If you drive on tarmac the most of the time I would say why not..
10-12-2007, 10:10 AM
Only Tarmac Smile
  4 Link setup and Traction brackets Jezza_hr 5 10,594 07-21-2014 09:12 PM
  Wanted: Link to Beams Blacktop engine manual pdf irishtwincam 7 9,130 01-03-2014 11:31 AM
Last Post: irishtwincam
  Mumford link Lajoosh 4 7,532 11-27-2013 09:01 AM
Last Post: Lajoosh
  Ecu ROM tuning Alex170984 4 5,982 10-13-2013 08:03 AM
Last Post: Apsogos
  Need help (4ac engine tuning) fullybuiltmiata 3 6,636 08-20-2012 09:25 PM
