The A6 Celica/Carina topic
06-24-2009, 11:13 PM
Post: #391
corona t140 series aye... never seen one here with those lights but will be keeping my eyes open for any more that pop up for sure.
"Carina Testing" at joe manji. shared driving between a friend and myself- basiacally i just did the munter O's at the end
http://www.youtube.com/watch?v=prTndh-xSks
3RZFTE TA63 Carina
http://www.youtube.com/watch?v=Rkk_2-dl7GE
06-24-2009, 11:35 PM
Post: #392
Great donuts! Especially the first ones before you get chased by the cone-guy! Big Grin
I think I'm convinced of the 1UZ being the right engine for a Carina! >Smile
BTW: I already found that video: I'm subscribed to kinloud on Youtube. Wink
[Image: AEU86 AE86 - The A6 Celica/Carina topic]
06-24-2009, 11:54 PM
Post: #393
Thats the leader of the joe manji days.
funny stuff
3RZFTE TA63 Carina
06-29-2009, 12:05 AM
Post: #394
knock knock- whos there?! not number one big end bearing anymore- DOH!!!
many laps of the pukekohe race track finally took its toll this weekend resulting in the death of the 1uzfe. not sure if its been on its way for a while or if it was simply due to a much tighter line over the mountain resulting in much higher side forces running the oil up and away form the pick up but on the bright side of things i finally have to do all the small and not so small things that were bugging me since getting it going initially.
So while the engine is out:
custom oil pan to cure the oiling problem
new engine mounts - the original ones work a treat but a little bulky in my mind- so will redesign them to be as slim and block hugging as possible to allow more room for the headers.
Proper headers- the current ones are fatory units hacked into an ungodly nightmare.
As for the engine- i just pulled the pan off and found that yes indeed number one bearing has spun on the crank- no damage to the crank luckily but the big end cap has a small deformation in it- will get some second opinions but what im thinking is new connecting rod at this point.
Stage Two tune here i come!!!
3RZFTE TA63 Carina
07-01-2009, 03:57 PM
Post: #395
Auch! Crying
BTW: what gearbox are you using for the 1uzfe? Dumb question
07-01-2009, 10:57 PM
Post: #396
AM using a W57 box witht the A1Turbos cast bellhousing.
3RZFTE TA63 Carina
07-15-2009, 01:14 PM
Post: #397
What do you think about a 2T-G head exchange for the 3T engine?
A buddy told me, that the whole engine replacement is not a quite good idea, because the loss of much torque (and gain power, i know, but i dont want to rev Granny to high rpm often Smile )
AndrewGL
07-15-2009, 01:49 PM
Post: #398
2TG to 3T is a lot of work... Might be easier to just swap the 3T crank into the 2T block and cut reliefs where necessary.
07-15-2009, 03:10 PM
Post: #399
I think the same applies to the 3T as the 2T: you need to change the waterpump, some pulleys, timingchains, other 'camshaft' in the engine, some block-holes-off-plates etc.
07-20-2009, 12:10 PM
Post: #400
found this
http://www.blocket.se/stockholm/Toyota_C...=23_10&w=3
cheers
Philip
  Another rusty old carina. roman 8 15,927 08-20-2007 12:56 PM
Last Post: roman
  Amazing -musseum ready- Celica nmwisima 26 26,520 03-13-2006 12:42 AM
Last Post: The Doctor
  ST185 celica evo 500 SekiguchiUeno 2 5,015 02-25-2006 08:53 AM
  Check out that old CELICA!!! nmwisima 12 14,243 07-10-2005 10:09 AM
