Throttle Bodies for 4age. What they gives?
05-08-2008, 11:00 AM
Hello!
I have possibility to buy individual throttle bodies to my 4age and I need your help. How much hp (about) it gives? What are other advantages? Better response to accelleration? I must know before buy if this really worth it ![]() ![]() Thanks a lot! |
05-08-2008, 11:39 AM
Hi there
On my car which I ran on the dyno before and after fitting quad throttles , I gained no more hp overall but more mid range power . Keep in mind you will probably have to run an aftermarket computer as well |
05-08-2008, 12:03 PM
You will definitely have better throttle response. To gain a respectable amount of hp, you will have to change ECU, camshafts and exhaust to match the ITB's setup. An increase to engine compression will give you even more power, and together with a good header you can reach about 200hp (with "huge" camshafts of course...
![]() ![]() JapanPower UoP Racing website UoP Racing videos Racing, because football, basketball, tennis & golf only require ONE ball.... |
05-08-2008, 01:21 PM
My 4age 16V is allready fully tuned. I've got:
-lightened flywhell -really, really high compression (I'm not mechanic, but I know that the header is planned or something ![]() -exhaust is also customed It had aftermarket computer (SMT6) but it was making a lot of trouble and now it's just standard. Yeah, SOUND!!! ![]() 200hp?? You think so?? But propably with a lot o troubles and problems :/ |
05-09-2008, 07:50 PM
I've seen ITB produce 10-12 HP through out the power band.
05-10-2008, 12:22 AM
F0Bman Wrote:I've seen ITB produce 10-12 HP through out the power band. This would be a reasonable expectation. ITB's will flow more air due to the "cleaner" design of the intake. And since the air path to each cylinder is identical, you can tune more aggressively, rather than having to tune to the leanest cylinder. The cool sound and improved throttle response are a bonus ![]() ![]() Cheers... jondee86 |
05-10-2008, 12:54 AM
I agree, they wouldn't give massive HP gains but better mid range and off course the noise!! Vid of my 4AGE with ITB's and standalone ECU.
http://www.youtube.com/watch?v=K5gmWtm-9ro&feature=user Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
05-10-2008, 10:38 PM
Wow!
![]() What ECU you're using? (and how much did you payed for that ![]() |
05-12-2008, 12:47 PM
I run a Perfectpower, XMSL, it was about 500quid GBP and does everything well, nothing fancy, but works ok for me, I have fitted it to another car aswell, no probs.
if you need any info let me know. Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
05-13-2008, 10:29 PM
longer stacks = more midrange torque
shorter stacks = more hp @ higher RPMs, but you'll lose bottom short stacks inside original plenum + stock intake = hp and torque gain @ midrange ![]() |
Can you identify this wheels? Will they fit AE86? | Ryo | 8 | 10,627 |
got seat belts. but they rolled up | MC_JP | 8 | 10,157 |
05-06-2014 04:04 PM Last Post: banpei |
Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 11,193 |
10-25-2013 05:13 PM Last Post: Apsogos |
Traction brackets what do they do? | slowboy2 | 4 | 10,040 |
03-25-2011 08:38 PM Last Post: NoHachi |
Alu crank pulley.. are they good? | Allexz | 20 | 29,172 |
03-29-2010 03:45 PM Last Post: jondee86 |
