Traction brackets what do they do?
03-24-2011, 06:37 PM
what is the function of a Traction brackets.
![]() toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
03-24-2011, 09:01 PM
Traction Brackets :
Installing these on lowered AE86's corrects the rear lower control arms (lower 4-link) geometry. What they do is change the angle the arm/link sits at, when it does that it allows the car to better apply a downward force on accel via the tires to the ground. Basically the suspension pushes against the car and forces the tire downwards, resulting in increased traction. It's something thats mostly noticed on acceleration. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
03-25-2011, 08:08 PM
ok. thanks for the info.
03-25-2011, 08:38 PM
It doesn't correct it..it changes it. The car never gets back to stock arm positions the way that the front RCA's gets things close again. To do that you either have to move the pickups upward on the body or all pickups on the axle downward. Just changing two of the four brackets introduces a whole new range of suspension behaviour. Some like it..some don't
Can you identify this wheels? Will they fit AE86? | Ryo | 8 | 10,908 |
4 Link setup and Traction brackets | Jezza_hr | 5 | 10,613 |
07-21-2014 09:12 PM Last Post: Bean |
got seat belts. but they rolled up | MC_JP | 8 | 10,402 |
05-06-2014 04:04 PM Last Post: banpei |
Setup steer-in versus traction | Dino86 | 6 | 8,153 |
11-15-2011 11:46 AM Last Post: Dino86 |
Rear Traction Brackets DIY? Dimensions ? | Uzelac | 5 | 6,890 |
04-23-2010 10:54 AM Last Post: boo50 |
