Rear Traction Brackets DIY? Dimensions ?
04-13-2010, 09:48 AM
Hi
Rear traction brackets are too simple not to DIY.
Does anyone know dimensions for holes arrangement ?
Do all aftermarket brackets have the same layout or some are for more and some for less lowered Hachis ?
Thanks
04-15-2010, 11:52 PM
Most brackets have the same layout for the upper part, as the axle brackets all have the holes in the same place. It's the lower your going to have to determine... I think 'most' put it about 50mm below the stock point. You can do more or less depending on how lowered you are.
04-22-2010, 02:51 PM
so does annyone have got some pictures with sizes. cause it is verry easy to make (y)ourselve Big Grin
Regards,
Roel
Gtsi-R
"Trust me, I was an engineer"
04-22-2010, 02:56 PM
I'm waiting for my car to return, and will take measures. About a week.
If someone can do it faster, great Smile
04-23-2010, 10:54 AM
Great idea.
It's very easy to cut them on digital plasma cutter and weld.
Very simple detail really.
owau no ka "I"
  DIY: a quick outline on why & how to set pinion angle. assassin10000 9 19,007 12-21-2016 10:28 PM
Last Post: ditn
  Quick question - Brake Pad Dimensions Lt86 2 5,534 06-07-2015 12:08 AM
Last Post: jondee86
  Dimensions clutch master cylinder bozu 2 6,389 04-16-2015 07:11 AM
Last Post: bozu
  4 Link setup and Traction brackets Jezza_hr 5 10,615 07-21-2014 09:12 PM
  Spindle dimensions, backing plate bolt pattern Rascal21 18 22,543 03-13-2014 11:45 AM
Last Post: Rascal21
