Throttle Bodies for 4age. What they gives?
05-08-2008, 11:00 AM
Hello!
I have possibility to buy individual throttle bodies to my 4age and I need your help. How much hp (about) it gives? What are other advantages? Better response to accelleration?
I must know before buy if this really worth it Wink Big Grin
Thanks a lot!
05-08-2008, 11:39 AM
Hi there
On my car which I ran on the dyno before and after fitting quad throttles , I gained no more hp overall but more mid range power . Keep in mind you will probably have to run an aftermarket computer as well
05-08-2008, 12:03 PM
You will definitely have better throttle response. To gain a respectable amount of hp, you will have to change ECU, camshafts and exhaust to match the ITB's setup. An increase to engine compression will give you even more power, and together with a good header you can reach about 200hp (with "huge" camshafts of course... Cool ). And don't forget the sound! Man this sound is so awesome, that is a good reason to go for ITB's!!! Thumbs up!
JapanPower
UoP Racing website
UoP Racing videos
05-08-2008, 01:21 PM
My 4age 16V is allready fully tuned. I've got:
-lightened flywhell
-really, really high compression (I'm not mechanic, but I know that the header is planned or something Tongue and I've got about 16bars)
-exhaust is also customed
It had aftermarket computer (SMT6) but it was making a lot of trouble and now it's just standard.
Yeah, SOUND!!! Big Grin I can just imagine how it will sound! (if now is really great!)
200hp?? You think so?? But propably with a lot o troubles and problems :/
05-09-2008, 07:50 PM
I've seen ITB produce 10-12 HP through out the power band.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
05-10-2008, 12:22 AM
F0Bman Wrote:I've seen ITB produce 10-12 HP through out the power band.
This would be a reasonable expectation. ITB's will flow more air due to
the "cleaner" design of the intake. And since the air path to each cylinder
is identical, you can tune more aggressively, rather than having to tune
to the leanest cylinder.
The cool sound and improved throttle response are a bonus Smile Smile
Cheers... jondee86
05-10-2008, 12:54 AM
I agree, they wouldn't give massive HP gains but better mid range and off course the noise!! Vid of my 4AGE with ITB's and standalone ECU.
http://www.youtube.com/watch?v=K5gmWtm-9ro&feature=user
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
05-10-2008, 10:38 PM
Wow! Huh Great project! MG + 4age that's just awsome!
What ECU you're using? (and how much did you payed for that Tongue) It was a lot of problems with my SMT6 (it was losing maps when acu was not connected), that's why now is standard one.
05-12-2008, 12:47 PM
I run a Perfectpower, XMSL, it was about 500quid GBP and does everything well, nothing fancy, but works ok for me, I have fitted it to another car aswell, no probs.
if you need any info let me know.
Ivan
05-13-2008, 10:29 PM
longer stacks = more midrange torque
shorter stacks = more hp @ higher RPMs, but you'll lose bottom
short stacks inside original plenum + stock intake = hp and torque gain @ midrange
[Image: AEU86 AE86 - Throttle Bodies for 4age. What they gives?]
  Can you identify this wheels? Will they fit AE86? Ryo 8 10,361 09-08-2021 12:48 PM
Last Post: Ryo
  got seat belts. but they rolled up MC_JP 8 9,906 05-06-2014 04:04 PM
  Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE Homem Bomba 3 10,954 10-25-2013 05:13 PM
Last Post: Apsogos
  Traction brackets what do they do? slowboy2 4 9,805 03-25-2011 08:38 PM
Last Post: NoHachi
  Alu crank pulley.. are they good? Allexz 20 28,446 03-29-2010 03:45 PM
Last Post: jondee86
