Tokico HTS spacer?
06-10-2007, 11:20 PM
Tokico HTS spacer?
original spacers
06-11-2007, 08:03 AM
Tokico HTS spacer?
sweet thank you DJexor
P.A.S.S Racing 148 S.8th Ave, Unit-F (626)961-6284 City of Industry [email protected] http://www.passracing.com |
06-11-2007, 09:01 AM
Tokico HTS spacer?
Come to think of it.. I should have my spacers lying around somewhere still since Jamiemirror custom made some 2cm ones for me
06-11-2007, 02:10 PM
Tokico HTS spacer?
SYM Wrote: sweet thank you DJexor no probs mate 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
06-11-2007, 07:55 PM
Tokico HTS spacer?
I got them from Max, as most of the others i think.
06-11-2007, 10:09 PM
Tokico HTS spacer?
Yeah got them through Max as well, I guess its Tokico thats a bit strange with it.
Anyways, I just checked, I still have the two 4cm spacers in my shed so if you want them... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
06-12-2007, 01:11 PM
Tokico HTS spacer?
Yes that would be great!
I also need a prothane bushings set. PM! |
07-07-2009, 09:51 AM
Tokico HTS spacer?
I just installed my HTS112 F&R set to my hachi.
I used a pair of spacers, custom made, but identical to the originals. The result is that my car is lower in rear, and higher in front. I use APEX springs. What am I doing wrong? P.S. "Cut" is a not acceptable word to your answers http://www.ae86.gr |
07-07-2009, 11:12 AM
Tokico HTS spacer?
I am just curious how you have forced those Apex springs to work on short stroke shocks(there have to be huge preload). Cut?
If not you probably need lower spacer underneath the front shocks and biger spacer above. Can you measure the distance between wheel centres and fender lips? Just curious how low it sits. p.s. I have still 2sets of high quality fensport springs laying around that i cannot use with my long stroke bilsteins. Are you interested? 4kg/mm front, 3kg/mm rear http://www.86ers.org All the hachies that Daytona can only dream about. |
07-07-2009, 11:32 AM
Tokico HTS spacer?
SekiguchiUeno Wrote:I am just curious how you have forced those Apex springs to work on short stroke shocks(there have to be huge preload). Cut?They are not short stroke! 112 are longstroke. The Fensports work better with HTS? I' ll measure and I'll post pics asap. http://www.ae86.gr |
trd solid spacer how to? | slowboy2 | 11 | 16,038 |
04-21-2012 08:13 AM Last Post: slowboy2 |
Long Stroke Springs - Espelier 40mm Tokico ??? | juantonwan | 20 | 17,045 |
05-11-2010 10:31 PM Last Post: jondee86 |
wheel rim spacer center bore, 60mm ? | Uzelac | 4 | 9,626 |
01-21-2010 08:10 PM Last Post: aussiefan |
Rear travel setup with Tokico HTS 102 | Uzelac | 5 | 9,070 |
05-19-2009 01:33 AM Last Post: Uzelac |
tokico HTS ? | Spy | 2 | 3,412 |
11-14-2006 08:15 AM Last Post: Max_Misawa |
User(s) browsing this thread: 15 Guest(s)
