Toyota Carina TA62 4A-GE 16v Redtop
10-17-2015, 12:34 PM
(09-28-2015 09:32 PM)banpei Wrote:  So you did get the indicators after all! Thumbs up!
And you got into the same trouble as I did with the brackets in the fenders. I ended up removing the brackets entirely and am still stuck at creating new ones.
I never bought the separate indicators, I used the ones I got for the second pair of headlights I bought. The actual lights I used are the ones I had in the Nissan King Cab lights since they were in better condition.
Creating new brackets? My car had mounting points for these lights after I removed the old inner brackets. For the outer brackets I just used some thin metal and fixed it to the lower part of where the fender was cut! Smile
10-21-2015, 08:41 PM
Yes if you remove the inner brackets they will fit. For the ones inside the fender I want to do it "properly" but they still haven't reached the top of the priority list yet. Wink
[Image: AEU86 AE86 - Toyota Carina TA62 4A-GE 16v Redtop]
12-22-2015, 09:03 PM
Haven't updated in a while but work still goes on. A bigport 4A-GE with HKS 256 cams and higher comp pistons has made its way in to the car, still using the smallport intake with a T3 adapter plate. all electronics were also moved from the smallport to the bigport, which means its running on a EUDM smallport ECU
First time running
12-22-2015, 11:44 PM
Nice! Thumbs up!
Any noticeable differences between the stock smallport and your new bigsmallport?
12-23-2015, 02:58 AM
Very interesting. Thumbs up!
Oem high comp pistons? If not what's their listed compression ratio?
12-23-2015, 07:15 AM
I haven't yet tried it. It has just started for the first time and i still need to run it in. But with it being christmas and all that kinda hasn't happend..
The guy who built the engine (It was part of the purchase of an AE86 my father made) was aiming for 150hp. That should make noticable difference from a 300 000km redtop!
Not sure what the pistons are but i think the guy said they gave the same compression as a stock redtop, but I'm pretty sure there is also a TRD headgasket in there, can't remember right now Tongue
12-23-2015, 11:23 AM
Nice build mate! Keep up the updates!
Jorda MotorSport
Keto Beams Project
01-07-2016, 12:57 PM
Nice !
Michael IPHIGENIE
http://www.zenky-racing.com
zenkyracing [AT] gmail.com (msn / email)
Member of Pandaz Ridaz Crew
02-05-2016, 09:40 PM
Not much has happend, but I'll throw in an update anyways!
I bought and installed a short shift kit from Cube Speed in Australia. Haven't tried it in motion yet but the shifter feels very solid and the throw sure is shorter than stock.
My fathers AE86 is coming along nicely with fresh paint new wheels and some other new goodies!
  82 Carina TA63 DGealon 9 14,207 10-21-2016 04:38 PM
  My Carina TA60 crxman 17 18,984 01-09-2016 10:17 PM
Last Post: nyberrg
  Project "Roku-ju" TA60 Carina Motax 24 37,718 03-05-2014 10:21 AM
Last Post: Motax
  Toyota Carina 1uzfe swap karos 22 39,943 11-05-2013 08:55 PM
Last Post: karos
  4ac to 4age redtop wiring question JDMjonSR5 1 3,907 04-16-2013 04:18 AM
Last Post: JDMjonSR5
