Trueno Digital dash kph to mph
11-15-2018, 04:25 PM
Greetings.
Should the AE86 I eventualy get come with a digital dash instead of an analogue one, how would i go about converting the displayed speed from KPH to MPH ? Links would be helpfull. Analogue dials would be easy enough, simply changing the dial face would be enough. But the digital one obviosly cant have that done. Cheers |
11-16-2018, 10:57 PM
You can't change the digital dash from kph to mph out of the box:
http://www.aeu86.org/forum/Thread-JDM-Di...h-question The digital gauge cluster doesn't support a multi scale speedo like the Celica Supra MA61 did with a simple push button to change it. You would be able to change the gear on the speedo cable with a factor 0.62, but the speedo will still read km/h. The fluerecent tube display does have the mph reading though, so with a little bit of fiddling in the electronics you would be able to put that right: http://club4ag.com/forums/viewtopic.php?t=15561 About the analogue dials: you can swap it for a UK gauge cluster. It already has everything in mph and all the connections should be correct too. 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
11-17-2018, 05:58 PM
(This post was last modified: 11-17-2018 06:02 PM by Bojack.)
(11-16-2018 10:57 PM)banpei Wrote: You can't change the digital dash from kph to mph out of the box: Aye i was thinking it would be a converter of some kind. Im not to concerned with the KPH/MPH indicator right of the bat, i can deal with that later down the line, but I do need a plan inplace to get the indicated speed in MPH. Im gunna look around for a 0.62 changer then. Any recommendations ? Again this is just incase the car i get has a Digi dash. Idealy ill be getting analgue, but im noting be picky. |
11-21-2018, 12:27 AM
I never bothered lol. my 86 and my Glanza still read KMH in the UK
Digital Dash | evfan42 | 190 | 255,427 |
05-03-2024 06:44 PM Last Post: banpei |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,237 |
Dash Waning Lights | pack | 7 | 3,890 |
10-06-2021 01:00 PM Last Post: pack |
Custom Dash Cluster | kazi | 14 | 19,403 |
Dash Lights | kazi | 3 | 5,517 |
09-12-2017 10:04 PM Last Post: kazi |
