Trueno Digital dash kph to mph
11-15-2018, 04:25 PM
Greetings.
Should the AE86 I eventualy get come with a digital dash instead of an analogue one, how would i go about converting the displayed speed from KPH to MPH ?
Links would be helpfull.
Analogue dials would be easy enough, simply changing the dial face would be enough. But the digital one obviosly cant have that done.
Cheers
11-16-2018, 10:57 PM
You can't change the digital dash from kph to mph out of the box:
http://www.aeu86.org/forum/Thread-JDM-Di...h-question
The digital gauge cluster doesn't support a multi scale speedo like the Celica Supra MA61 did with a simple push button to change it. You would be able to change the gear on the speedo cable with a factor 0.62, but the speedo will still read km/h.
The fluerecent tube display does have the mph reading though, so with a little bit of fiddling in the electronics you would be able to put that right:
http://club4ag.com/forums/viewtopic.php?t=15561
About the analogue dials: you can swap it for a UK gauge cluster. It already has everything in mph and all the connections should be correct too.
[Image: AEU86 AE86 - Trueno Digital dash kph to mph]
11-17-2018, 05:58 PM (This post was last modified: 11-17-2018 06:02 PM by Bojack.)
(11-16-2018 10:57 PM)banpei Wrote:  You can't change the digital dash from kph to mph out of the box:
Aye i was thinking it would be a converter of some kind.
Im not to concerned with the KPH/MPH indicator right of the bat, i can deal with that later down the line, but I do need a plan inplace to get the indicated speed in MPH.
Im gunna look around for a 0.62 changer then. Any recommendations ?
Again this is just incase the car i get has a Digi dash. Idealy ill be getting analgue, but im noting be picky.
11-21-2018, 12:27 AM
I never bothered lol. my 86 and my Glanza still read KMH in the UK
  Digital Dash evfan42 190 300,099 05-03-2024 06:44 PM
  Digital speedometer on stock dashboard FanIsHere 0 2,403 11-09-2022 01:36 PM
Last Post: FanIsHere
  Dash Waning Lights pack 7 6,239 10-06-2021 01:00 PM
Last Post: pack
  Custom Dash Cluster kazi 14 24,823 10-24-2017 09:05 PM
Last Post: kazi
  Dash Lights kazi 3 6,783 09-12-2017 10:04 PM
Last Post: kazi
