Trueno - Headlight Rods
04-26-2012, 09:33 PM
Just replace the stock rod with two threadend rods at the end and an adjusting nut in between, so you can exactly turn it to the lenght you need.... Thought about that? Wave
AE86 Full Hybrid - Burns rubber and gasoline
04-27-2012, 12:01 AM
YEs that's what i'm going to do on mines... But the measurement is to get the ideal length on mines only!
Thumbs up!
04-27-2012, 01:34 AM
165mm center circle to center circle
04-27-2012, 10:42 AM
Thanks! Thumbs up!
04-27-2012, 10:45 AM
You are welcome Brother
04-27-2012, 11:23 AM
With that i can now make mines that same size and if they still wont open, the problem is on the small metal piece that makes the rod move!
Regards!
  AE86 Headlight + wiper wiring (levin) bozu 11 16,794 09-19-2017 02:06 PM
  Trueno headlight help kazi 9 13,187 04-20-2017 09:37 AM
Last Post: kazi
  TRUENO - LHD headlight solutions pack 11 14,388 09-21-2016 10:29 AM
Last Post: pack
  Peculiar headlight issue - main beam Jezza_hr 3 6,076 10-04-2015 09:25 PM
Last Post: Jezza_hr
  LHD W.G (West Germany) wires from dimmer & dash switch to headlight relays? Rascal21 11 15,421 07-07-2014 09:16 AM
