Trueno - Headlight Rods
04-26-2012, 09:33 PM
Just replace the stock rod with two threadend rods at the end and an adjusting nut in between, so you can exactly turn it to the lenght you need.... Thought about that?
AE86 Full Hybrid - Burns rubber and gasoline |
04-27-2012, 12:01 AM
YEs that's what i'm going to do on mines... But the measurement is to get the ideal length on mines only!
04-27-2012, 01:34 AM
165mm center circle to center circle
04-27-2012, 10:42 AM
Thanks!
04-27-2012, 10:45 AM
You are welcome Brother
04-27-2012, 11:23 AM
With that i can now make mines that same size and if they still wont open, the problem is on the small metal piece that makes the rod move!
Regards! |
AE86 Headlight + wiper wiring (levin) | bozu | 11 | 15,737 |
09-19-2017 02:06 PM Last Post: banpei |
Trueno headlight help | kazi | 9 | 12,337 |
04-20-2017 09:37 AM Last Post: kazi |
TRUENO - LHD headlight solutions | pack | 11 | 13,447 |
09-21-2016 10:29 AM Last Post: pack |
Peculiar headlight issue - main beam | Jezza_hr | 3 | 5,669 |
10-04-2015 09:25 PM Last Post: Jezza_hr |
LHD W.G (West Germany) wires from dimmer & dash switch to headlight relays? | Rascal21 | 11 | 14,543 |
07-07-2014 09:16 AM Last Post: Ivan141 |
