Tuned 4AGE results
04-03-2009, 01:00 PM
Tuned 4AGE results
Robokill's engine spanked 75% of all the nearly stock 20v's that where present on the dyno that day.. really good results for a street-driveable engine (no lumpy cams) on a stock ecu.
04-03-2009, 03:21 PM
Tuned 4AGE results
What cam timing did you set witht he mismatc hed catcams?
http://www.skynet.ie/~eireae86 |
04-04-2009, 07:37 PM
Tuned 4AGE results
robokill Wrote: I have almost identical setup with the Catcams 7105138 although I have yet to put it on the rollers. What timing are you using for your cams Robokill ? An analogue brain in a digital World |
04-04-2009, 09:31 PM
Tuned 4AGE results
My engine from 2008:
7rib 4age bigport crank, rods and pistons ported & polished bigport head raised CR 11:1 HKS 272 8,1 in/ex camshafts with ajdustable gears HKS valvesprings HKS oil up kit Small port oil pump Greddy airfilter TRD header 4-1 + 2,5" freeflow exhaust lightened flywheel without TVIS factory ECU (intake cam retarded 5 degrees, exhaust cam retarded 2 degrees, base timing advance 12 degrees) engine worked with lean Air fuel ratio 14-15 above 5000rpm, but survived some races... 133,7 whp about ~160hp on crank ![]() This year I made some improvement (AE101 ITB and MegaSquirt) but haven't dynoed yet. http://ae86.blog.hu - closed 2006 Toyota Corolla Verso 2.2 D4-D 1992 JDM Nissan Silvia PS13 RB26DETT powered |
04-04-2009, 10:34 PM
Tuned 4AGE results
Heres mine, 4AGE 3 Rib big port, HKS 264 cams,adj pulleys, open standard plenum, MFE ECU. trust exhaust manifold,TVIS removed. Engine rebuilt in Japan so unknown CR. 133.1 HP @ the wheels
04-05-2009, 01:53 AM
Tuned 4AGE results
Using -17 degree timing. Building another 4age atm lets see how that turns out
![]() Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
04-05-2009, 10:39 PM
Tuned 4AGE results
robokill Wrote:Using -17 degree timing. Building another 4age atm lets see how that turns out max lift at 95/95? http://www.skynet.ie/~eireae86 |
04-16-2009, 10:01 AM
Tuned 4AGE results
Hi, I have also Catcams.
My engine: Smallport head (blueprinted) 300CC injectors 260 in 9mm lift (Catcams: 7105137) 252 out 8.5mm lift (Catcams: 7105137) Standard intake with open air filter Megasquirt MS2extra Super 98 fuel original MR2 exhaust 0,8mm TRD MHG I use the original timing 110/110. (With the thinner gasket it should be about 112/108°) With the calculation function from MegaLogviewer I have about 110hp on the wheels at 7000rpm and 100hp@6000 where I have max torque 90ftlb. Compared to another car I should have about 140hp on the engine. I think there are a few HP missing. Maybe the exhaust is restricting the engine to much or the timing is not perfect. I'll soon get it on the dyno. It would be great if you can post your timings. |
04-16-2009, 11:12 AM
Tuned 4AGE results
max78, I think you have somethings to upgrade before the exhaust. You should get the cam timing down to 100/100 or 105/105 and check ignition timing.
I would upgrade intake manifold before exhaust. Removing T-VIS is also a must do with those camshafts, I think! You should also check your compression ratio. Maybe raising it shaving the head would give you extra hp. Best regards |
04-16-2009, 11:51 AM
Tuned 4AGE results
thanks apardal, I set the cams to 110/110 because the datasheet for the cams tell me this.
Isn't 100/100 a bit too much overlap, don't you loose alot power at low rpms. I have a Walker muffler (It's should be similar to the original). I have no TVIS because I have the small port engine. And compression is on the small port 10,4:1 and a bit higher with the thinner MHG. Ignition timing is at 32° at high rpm and load. Between 12,5 and 13,5 AFR is nearly no power difference. Best regards |
Max a 16v 4AGE can be tuned to? | heshan | 20 | 56,261 |
04-21-2009 08:31 PM Last Post: banpei |
Silvertop burning oil - compression results | Jezza_hr | 3 | 4,848 |
10-18-2008 02:51 AM Last Post: jondee86 |
AE86 Dyno Results! | Wraith | 9 | 14,560 |
10-16-2006 09:13 AM Last Post: Mux213 |
