Tutorial : Megasquirting an European (MAP) AE86 (4age)
03-23-2009, 12:52 PM
will_drift_4_food Wrote:Awesome info. When you hooked up the injectors management, you need to check that all the four injectors got 12V from ECU (ignition switch ON). I made new injector wiring, because my original harness didn't work. Almost started yesterday ![]() http://ae86.blog.hu - closed 2006 Toyota Corolla Verso 2.2 D4-D 1992 JDM Nissan Silvia PS13 RB26DETT powered |
03-23-2009, 01:39 PM
Yeah, They all have +12V when the Key is "ON". I need to make sure that the injectors maintain that during cranking. I got a set of noid lights the other day; I need to make sure that they are firing at all.
I got the engine, harnesses, transmission, etc. as a lot from a guy that was going to use it for a Locost/Seven project. I think the harness is a Euro MAP harness, but I don't know if the ECU is Euro or JDM. The injectors are blue, low impedance injectors. I know that the ignitor I received is an VAST ignitor. But, the dizzy was an ESA dizzy. So, nothing seems to go together. I have since purchased two ESA ignitors, but aside from the fact that they plug into the harness better, I am still right where I started. I'll keep at it. Jason Clark JC Atlanta, GA 1984 AE86 SR5 Coupe 1987 MA70 (60-1,.70A/R; AEM EMS) 1994 Honda Accord EX |
03-23-2009, 03:06 PM
AE86_Z Wrote:When you hooked up the injectors management, you need to check that all the four injectors got 12V from ECU (ignition switch ON). I made new injector wiring, because my original harness didn't work. the 12v shouldn't come from the ecu , they need to come from your harness.... the only connection between ecu and injectors is the ground wire. Injectors should always have 12v+ (with key switch ON) and the ECU gives ground to the injectors for them to fire. good work ![]() |
03-23-2009, 11:38 PM
Sorry.... 12V coming from the harness, from a switched battery source, of course.
03-24-2009, 10:18 PM
Hi guys!
We made it: ![]() ![]() ![]() ![]() ![]() http://www.youtube.com/watch?v=1j1hBWq78xo Thanks for your help guys: ![]() ![]() ![]() ![]() ![]() Gon Apardal ZDoman That was a real team work ![]() http://ae86.blog.hu - closed 2006 Toyota Corolla Verso 2.2 D4-D 1992 JDM Nissan Silvia PS13 RB26DETT powered |
03-24-2009, 10:31 PM
I'm really happy for you mate
03-29-2009, 09:56 PM
Hi guys!
My engine is ready to tune, today we did the 1st run with MegaSquirt: ![]() ![]() ![]() http://ae86.blog.hu - closed 2006 Toyota Corolla Verso 2.2 D4-D 1992 JDM Nissan Silvia PS13 RB26DETT powered |
03-30-2009, 12:36 AM
03-30-2009, 01:01 AM
God damn, great work guys!
"Bad" thing is i allready started to search the net for great MS deals. Got any recommendation ? ![]() |
03-30-2009, 09:45 AM
Uzelac Wrote:God damn, great work guys! Thx ![]() You can buy all the things what you need from diyautotune.com. Cheap prices, very fast delivery. Regards, Z http://ae86.blog.hu - closed 2006 Toyota Corolla Verso 2.2 D4-D 1992 JDM Nissan Silvia PS13 RB26DETT powered |
AFM to Map Conversion | ps13michi | 3 | 3,597 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 11,825 |
European/UK vs Japanese Levin "Glass Grill" | mad.matt | 3 | 6,035 |
10-20-2017 02:47 PM Last Post: mad.matt |
extracted freedom ecu 16v ignition map | ditn | 7 | 9,285 |
smallport question AFM or MAP? | fax0815 | 5 | 8,613 |
05-17-2014 05:07 AM Last Post: jondee86 |
