Tutorial : Megasquirting an European (MAP) AE86 (4age)
07-09-2013, 12:53 PM
Post: #61
You could add some advance while reaching some optimal cooling set point and/ or open the idle valve more. Keep an eye in AFR values because more advance or air will burn more lean.
IAT/CLT Related Ignition
Warm up mode
pack Wrote:So i have my car running ITB's the way gon explained.
Car is working now and i just have a question.
In a cold start when i crank the engine, the idle is way too low (700rpm)
But when the car warms up the rotation goes to like (1400rpm)
I'm using a ICV (idle control valve) with the itb's.
Anyone? Smile
07-15-2013, 05:52 PM
Post: #62
Solved! Thumbs up!
01-09-2014, 12:10 PM
Post: #63
Hi everyone!
Anyone with ignition tables for a stock engine and/or tuned engine?
16V
Thanks
01-09-2014, 08:29 PM
Post: #64
check on diyautotune.com - there's an msq available for download that comes with the mspnp
01-09-2014, 08:33 PM
Post: #65
But the ignition map is not tuned for the 4AGE.
It has the basic setup to start the engine, but not a ignition map tuned in dyno. Thumbs up!
01-09-2014, 08:36 PM
Post: #66
pack Wrote:But the ignition map is not tuned for the 4AGE.
every engine is different so there is no perfect map that anyone can send you. It should be good enough to get you started though. Also I think it was made on a dyno as they took it from their own MR2 build, before they went turbo.
01-09-2014, 11:12 PM
Post: #67
I have mine set up running with no problems.... But wanted to make sure the ignition timings are correct or am i using values that are restricting my engine... Evil
01-09-2014, 11:23 PM
Post: #68
pack Wrote:I have mine set up running with no problems.... But wanted to make sure the ignition timings are correct or am i using values that are restricting my engine... Evil
Unfortunately only a dyno will tell you that, there's no shortcut around it.
Save up, find a good deal and have it checked.
  AFM to Map Conversion ps13michi 3 3,386 01-06-2022 10:34 AM
Last Post: ps13michi
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,429 02-10-2020 06:39 PM
Last Post: Power_uP
  European/UK vs Japanese Levin "Glass Grill" mad.matt 3 5,845 10-20-2017 02:47 PM
  extracted freedom ecu 16v ignition map ditn 7 9,077 08-22-2016 10:01 AM
Last Post: ditn
  smallport question AFM or MAP? fax0815 5 8,433 05-17-2014 05:07 AM
Last Post: jondee86
