Type of carbs to suit 4ag
02-08-2013, 10:10 AM
thank you all for keeping up with this topic
yeah i want power aswell locked diff at the rear 160hp thats enough to go side ways. i really want fcr setup as above its best with trottle response. now are you saying fcr does not sound great and back fires? NoHachi: more info please? also guys in the meantime saving for the fcr carb i am running the engine as efi the engine is rebuilt zero kmz smallport will this setup run the motor well? http://www.trademe.co.nz/Browse/Listing....ermanent=0 |
02-08-2013, 10:45 PM
That setup is stock aside air filter and TB position. Beside it's missing distributor to be complete.
You will gain nothing with stock ECU and stock intake. |
02-09-2013, 02:29 AM
hi i recomend fcr carbs also all race bikes run fcr and not some injection system .fcr are the best carbs on the market .also now the famous trd of keiichi tsuchiya now run with fcr's .the most n2 ae86 car 80% of them run with fcr , are they stupid? .
check drug bikes what they use all of them use fcr the make really a lot of power and if you want more power they put lectron carbs becose fcr's are 41mm and if you have really big engine they are not inuf lectron make until 50mm carbs similar to fcr the one that i get for my beams engine . the problem with the carbs is that you cant control electronic the feul consamption the yamaha m1 when rossi whent the first time was havin fcr carbs ,yes a motogp bike was usin carbs . with change of regulation about the feul wasent possible to make it to the end off the race so the put injection system so the control the power and the consumption of the engine .the good carbs like fcr and lectron give as much power an engine can get some times iven more than some injection systems. 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,599 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 10,898 |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,268 |
SOME 4AG valve spring specs | oldeskewltoy | 5 | 13,295 |
05-04-2015 01:17 PM Last Post: Project D |
ford type 9 gearbox with 4age engine | filh | 29 | 48,306 |
01-11-2015 01:02 PM Last Post: filh |
