Tyre recommendation 195/55 or 195/50
08-07-2010, 04:01 AM
Pretty keen to get some feedback on this, for and against, just looking for various opinions.
My wheels are 15x8.5
Cheers
http://www.super86.co.nz
08-07-2010, 11:10 AM
personaly I'd go with the 195/50 - it's a bit smaller than the original but not by much... 195/55 is ~3% more or you could even go with 205/50 which is ~1.5% bigger than OEM... realy depends what you do with the car. Daily driver, Motorway miles, Drifting, Gripdriving etc...
08-07-2010, 04:59 PM
@bean bandit don't you think that as his rims are 8.5"s 55 is a better choice as the 50s may stretch too much..??
@super86 I think going for 205s will be better personally unless you want to have that beautiful stretched effect..
Cheated on my いたずらな女の子 and now I can't get enough of her..
08-07-2010, 05:12 PM
as I said - it depends on what he uses the car for ... personaly I'd go for the 195/50.
08-07-2010, 11:06 PM
Use is hillclimb and trackday, but definitely would have concerns over a 205 being too wide to fit under stock lipped and rolled guards.
It has previously had 195/55's on 8's and they were fine - just wondering if there was any advantage to going to 50 series?
[Image: AEU86 AE86 - Tyre recommendation 195/55 or 195/50]
08-08-2010, 01:07 AM
I'm on 195/50.
Take "smaller" tire actualy have some advantages.
The first is obviously the size: smaller circumference act like a smaller final gear. So have less top speed but you have more torque (you have to consider that your speedometer will not be accurate)
The second is the weight : same effect than a lightest flywheel (less power lost)
08-08-2010, 02:00 AM
Correct me if I'm wrong but having a lower profile definitely help you on tighter corners as well specially in drifting..
08-08-2010, 10:16 AM
if you do hillclimbing, see if you can fit the 205/50 or even better 205/45 (smaller than OEM)... else go with the 195/50
08-09-2010, 08:25 PM
195/50 are usually much cheaper...
  Tyre load index Blaze0010 1 557 11-29-2024 09:45 AM
  Help on Tyre selection - asap - PLEASE! Okami 15 20,412 01-31-2011 02:50 PM
Last Post: totta Crolla
  Wheel geometry and tyre pressure on (near) stock AE86 Apolan 2 5,862 08-12-2010 04:30 PM
Last Post: Project D
  195/50/15 Tires? Bubble_Drift 20 20,711 09-05-2007 02:37 AM
Last Post: filh
  rim and tyre size? Aaron 37 32,506 02-16-2007 10:34 AM
Last Post: Denmark
