Using stock gauges with an engine conversion
10-03-2013, 02:15 PM
Is it possible to get the original rev meter and speedometer to work with a CA18DET engine and gearbox?
10-03-2013, 03:56 PM
Yes..
Needs a cable drive for the speedometer (I've seen an ae86 cable stuffed into a CA18 gearbox working), but without a different ratio gear it will show the wrong speed for sure. Tachometer can be used with ECU signal with a tach signal booster. FABRICA MI DIEM, PVNC! |
10-03-2013, 05:42 PM
Ivan141 Wrote:Tachometer can be used with ECU signal with a tach signal booster. I would recommend using the Omex one for this, it's inexpensive and easy enough to fit. |
10-03-2013, 10:20 PM
Hi Jezza, do you have a link to the Omex part?
I've been looking at the speedometer, it seems I need to buy a mechanical speedo drive for my gearbox (which doesn't seem easy to find). I'll also need to buy a cable. My diff is a 4.6 so i'll need to get a gear to match. It all seems like a pain but hopefully worth the effort |
10-03-2013, 11:34 PM
You can also buy a part that lets you set the speed yourself+cable,but forgot the name.Will look it up.
10-04-2013, 01:10 AM
Escy Wrote:Hi Jezza, do you have a link to the Omex part? I deal with omex, they dont show the converter on their page. I blive they retail at 25gbp +shipping to wherever you need it send to. They ment to convert a + square signal to a - peak signal. So if your Nissan Ecu got a digital output, as in square and +, the omex converter works very well! 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
10-04-2013, 10:43 AM
Omex converter is 15 gbp.. look for Omex Tachometer driver, you'll find it in webshops. Emerald also sell a tach driver, but it's 35GBP IIRC.
You can make these converters yourself (I have built quite a few), but even I will no longer invest time and effort into something that can be bought for 15GBP. Thats a properly fair price and you get production quality too. FABRICA MI DIEM, PVNC! |
10-04-2013, 03:42 PM
If all else fails, you can send Omex an E-mail directly and inform them of what you need. [email protected]
20v Blacktop conversion.... | Mylesmck | 0 | 833 |
04-29-2024 05:48 PM Last Post: Mylesmck |
Kouki to Zenki Levin grill conversion? | Mylesmck | 6 | 3,501 |
02-08-2024 10:30 AM Last Post: r.ave |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,963 |
AFM to Map Conversion | ps13michi | 3 | 4,257 |
82mm Stock compression Pistons | apardal | 4 | 3,573 |
