Vacuum Sensor/line hook up help.
04-10-2008, 08:29 AM
Okay I am running a pre-model Japanese Blue Top 4AGE and I think I have everything hooked up as far as the vacuum lines and all are concerned. I can take pictures if need be also. But right now I have the two ports on the throttle body looped and in the back of the intake one is running to the fuel rail ( Fuel Pressure Regulator? ) the next to the MAP sensor and the third and last is capped. The car has no EGR 'emissions' stuff on it from what I can tell.
Is that right??
I have seen pictures of other AE86's with MAPed engines and some look to be the same as how I hooked it up but some seem to have other sensors that are ran off the two ports on the throttle body???
Can anyone clear this up for me please. D= Pictures would help as well if posible. I want to hopefully have my Hachi running next week..
PS: can anyone tell me where the other lines run to around the throttle body? Like the Power steering lines and I think there is two more larger lines...
Also so I do not go around making more threads I was wondering if the O2 sensor off a US GTS would happen to work on a MAPed Blue Top? They are both one wired sensors But I just wanted to make sure as my Stock one has the wire ripped out and I happen to have a used US GTS one laying around.
Messages In This Thread
Vacuum Sensor/line hook up help. - Nanaki - 04-10-2008 08:29 AM
Things you don't need.... - jondee86 - 04-10-2008, 09:34 AM
[] - Nanaki - 04-14-2008, 11:52 PM
[] - Nanaki - 04-16-2008, 06:29 AM
[] - banpei - 04-16-2008, 04:20 PM
[] - parrot - 04-17-2008, 05:14 PM
[] - Nanaki - 04-17-2008, 09:22 PM
[] - Nanaki - 04-17-2008, 09:27 PM
[] - parrot - 04-18-2008, 01:20 AM
[] - Nanaki - 04-18-2008, 06:13 AM
[] - parrot - 04-18-2008, 06:28 AM
[] - F0Bman - 04-18-2008, 08:24 AM
Do you wash and wipe ?? - jondee86 - 04-20-2008, 08:50 AM
[] - parrot - 04-20-2008, 04:21 PM
  Lambda sensor wiring sam3007 10 4,681 05-23-2022 10:00 PM
Last Post: The Doctor
  fuel line hose from the pump Wikizz 4 6,151 10-16-2017 07:11 PM
Last Post: jdm86gtz
  US-spec vacuum hard lines LordTD 2 5,109 04-27-2015 07:18 PM
Last Post: Project D
  AE86 Engine Coolant Temp Sensor izanagi 8 20,596 09-06-2014 05:47 PM
Last Post: izanagi
Bug brake line leaking - how to fix ? MC_JP 2 4,402 04-28-2014 09:47 PM
Last Post: MC_JP
