Valve sound
03-21-2007, 09:49 PM
Valve sound
Hi there
I have bought my hachi two weeks ago. The previous owner told me that he had rebuilt the engine. I don't dought about it because the engine works preety well. But this week every morning when i start my engine i hear a noise like valve knocking till the engine gets to its normal temperature. Then the sound stops (maybe there is a sound but not so loud as in the begining) Is this normal? Perhaps my engine oil is wrong. I use 15/40 mineral. I have change it 1000 km ago. The rebuilt took place 40000 km ago. Should i have to adjust my valves? Tell me your opinion Toyota Corolla KE30 + Toyota Corolla AE86 |
03-22-2007, 07:09 AM
Valve sound
I've heard of minor 'valveknock' even on engines that have intrusionless geometry immediately after a rebuild, but i'd say 40 000 km is well enough not to consider it a fresh build.... Don't know, waiting for the gurus to say, i guess..
03-22-2007, 10:17 AM
Valve sound
Could you check whether the noise gets louder after you rev the engine and suddenly close the throttle?
Temperature dependent knock noises always make me think of a conrod bearing failure A wheel to steer the front of the car A pedal to steer the rear |
03-22-2007, 10:31 AM
Valve sound
No
If the engine comes to its normal temperature the sound dissapears (maybe it is not so loud) If i rev the engine and suddenly cut the throttle nothing happens. Everything works normal. Toyota Corolla KE30 + Toyota Corolla AE86 |
03-22-2007, 10:47 AM
Valve sound
Use quality oil filter (genuine Toyota is cheap and good). Change the oil too with some like 10-40 semi-synth. IMHO change the oil and filter immediately.
03-22-2007, 10:55 AM
Valve sound
I do use the genuine oil filter but i'll try different oil
03-22-2007, 12:37 PM
Valve sound
Try switching from mineral to semi-synth, could make all the difference you need...
03-22-2007, 01:03 PM
Valve sound
Τhis noise, was there from the the first day you took it???
Or it has appeared after a while??? |
03-22-2007, 01:46 PM
Valve sound
I sense con rod bearing caps .......
If it is , u should change them before the crank gets damaged ..... |
03-22-2007, 01:51 PM
Valve sound
@ Akis 308
I haven't notice it from the first day, but maybe i didn' t pay so much attention these first days. @ gon I'll check it out man. Thanks a lot Toyota Corolla KE30 + Toyota Corolla AE86 |
4AGE Valve Buckets Scored | Steller Engineering | 2 | 880 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 1,348 |
HKS valve springs | totta Crolla | 3 | 2,160 |
Valve clearance | leon205gti | 7 | 8,573 |
11-25-2016 03:24 AM Last Post: oldeskewltoy |
16v oversize valve seats | harkes | 9 | 12,409 |
09-20-2016 05:04 PM Last Post: oldeskewltoy |
