Valve sound
03-21-2007, 09:49 PM
Valve sound
Hi there
I have bought my hachi two weeks ago. The previous owner told me that he had rebuilt the engine.
I don't dought about it because the engine works preety well.
But this week every morning when i start my engine i hear a noise like valve knocking till the engine gets to its normal temperature. Then the sound stops (maybe there is a sound but not so loud as in the begining)
Is this normal?
Perhaps my engine oil is wrong. I use 15/40 mineral. I have change it 1000 km ago.
The rebuilt took place 40000 km ago. Should i have to adjust my valves?
Tell me your opinion
Undecided
03-22-2007, 07:09 AM
Valve sound
I've heard of minor 'valveknock' even on engines that have intrusionless geometry immediately after a rebuild, but i'd say 40 000 km is well enough not to consider it a fresh build.... Don't know, waiting for the gurus to say, i guess..
03-22-2007, 10:17 AM
Valve sound
Could you check whether the noise gets louder after you rev the engine and suddenly close the throttle?
Temperature dependent knock noises always make me think of a conrod bearing failure Undecided
03-22-2007, 10:31 AM
Valve sound
No
If the engine comes to its normal temperature the sound dissapears (maybe it is not so loud)
If i rev the engine and suddenly cut the throttle nothing happens. Everything works normal.
03-22-2007, 10:47 AM
Valve sound
Use quality oil filter (genuine Toyota is cheap and good). Change the oil too with some like 10-40 semi-synth. IMHO change the oil and filter immediately.
03-22-2007, 10:55 AM
Valve sound
I do use the genuine oil filter but i'll try different oil
03-22-2007, 12:37 PM
Valve sound
Try switching from mineral to semi-synth, could make all the difference you need...
03-22-2007, 01:03 PM
Valve sound
Τhis noise, was there from the the first day you took it???
Or it has appeared after a while???
[Image: AEU86 AE86 - Valve sound]
03-22-2007, 01:46 PM
Valve sound
I sense con rod bearing caps .......
If it is , u should change them before the crank gets damaged .....
03-22-2007, 01:51 PM
Valve sound
@ Akis 308
I haven't notice it from the first day, but maybe i didn' t pay so much attention these first days.
@ gon
I'll check it out man. Thanks a lot
  4AGE Valve Buckets Scored Steller Engineering 2 880 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,348 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 2,160 05-25-2022 10:24 PM
  Valve clearance leon205gti 7 8,573 11-25-2016 03:24 AM
  16v oversize valve seats harkes 9 12,409 09-20-2016 05:04 PM
User(s) browsing this thread: 28 Guest(s)
