Velocity stacks = more power, now which to get?
10-12-2011, 01:30 PM
what the mods of your engine??
10-12-2011, 02:44 PM
rooty Wrote:mech5107 Wrote:Don't forget that on a dyno, the hood is open and the stacks suck in clean and cold air. Do what? Don't have plenum? In road driving, the cold air will go through the rad and get hotter. Also the air will then get "trapped" under the hood and get hot from the engine. If with closed hood the itbs draw cold air, then all the engine bay should be cold... Japan 4 Ever |
10-12-2011, 03:00 PM
mech5107 Wrote:Do what? Don't have plenum? In road driving, the cold air will go through the rad and get hotter. Also the air will then get "trapped" under the hood and get hot from the engine. I'm questioning a dyno with an open hood. Kind of pointless if you want real-life accurate results |
10-12-2011, 03:53 PM
your plenum is to small - the basic design doesn't look too bad
from the pic I can see two issues, one too small; second the plenum roof at the 4th stack is most probably too close unless your stacks a very short... you could try to increase the plenum on the lower end and feed the air through there, this has two advantages, the first stack won't be force fed as much and you gain more volume. PS: I agree a dyno run with an open hood is as realistic as oem figures... probably one of the best dyno setups I've ever seen is this one based in the Neatherlands close to the German/Belgium border AE86 ex-daily |
10-12-2011, 07:14 PM
Petros AE86 Wrote:what the mods of your engine?? 38mm 4 into 1, 650mm long headers 1mm oversized valves (intake and exhaust) Supertech valves springs 288 degree 10mm lift cams Toda Cam gears Custom narrow skirt CP pistons Tomei rods ARP bolts throughout ACL bearings Excedy lightweight flywheel 15:1 compression Balanced Vipec ECU Coil on plug ignition |
10-13-2011, 04:58 AM
Good to see the DynaPack hub dyno... designed and built right here
in New Zealand EDIT: Am I the only one who can't see the pics in the link given by the original poster ?? That's why I am posting the links up again. EDIT: Deleted the pic... no need to post it twice Cheers... jondee86 |
10-13-2011, 08:47 AM
jondee86 Wrote:Good to see the DynaPak hub dyno... designed and built right here fixed the link, don't know what wasn't good but it works now Dynapack is my personal favorite - I almost bought one before I decided to live a life all over the world. The value and quality is awesome and being more portable than most conventional dynos offers a lot of opportunity to regain the investment. AE86 ex-daily |
10-13-2011, 03:58 PM
OT:
What is the approximate price of Dynapack setup like this one ? |
10-13-2011, 04:06 PM
well Dynapack is only the Dynamometer - the fan setup in the picture above is a custom build.
If you are on a budget the tend to have test and refurbished systems all the time. So you're looking for around 30-40kUS$ for the smallest 2WD setup which is good for around 400hp send me your E-Mail through PM and I'will forward the information I have - they are from March 2010 so prices are slightly higher as they got cheaper by now. Or contact them yourself http://www.dynapack.com PS: for what I had planed back in 2010 - I would have had the investment easily back within a year. AE86 ex-daily |
11-03-2011, 12:49 AM
Update ?
Airbox or just stacks ? I'm interested because I plan to put some some box over my ITB's. |
20v BT - which oil pump? | Mylesmck | 4 | 2,866 |
Rim width. Which is best.... | Dino86 | 5 | 6,876 |
which connector is this | ditn | 7 | 7,796 |
07-27-2015 11:24 AM Last Post: pack |
Haslbeck front spoiler, which foglights? | wouter86 | 2 | 5,133 |
02-15-2015 11:14 AM Last Post: ditn |
which piston is this? | ditn | 10 | 12,235 |
07-04-2014 03:18 PM Last Post: Bean |
User(s) browsing this thread: 12 Guest(s)
