Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE
10-25-2013, 01:12 PM
Hello guys, here is a video that I believe will help a lot of AE86 owners. If you have one (or more of the following symptoms):
[list:74615f93de]Jerkiness when touching the accelerator when in gear or when letting off the clutch when going through the gears Rough idle Strange clicks coming from the engine bay when touching the accelerator when in gear [/list:u:74615f93de] You should definitely adjust your TPS (Throttle Position Sensor) on your Toyota 4A-GE engine! Here it is : If you like this video dont forget to subscribe to my channel as I will post more videos of this sort of tuneups and repairs! Take care :-) E12 2.0 D-4D - 2002 - "Mariazinha" - G6R - 1998 - "Bebedolas" - AE86 - 1987 - "Charutinho" - Check out my Youtube Channel with lots of AE86 DIY Guides! |
10-25-2013, 02:51 PM
Love your DIY Vids, great work
10-25-2013, 05:13 PM
4age 16v to FR 20VT |
Lambda sensor wiring | sam3007 | 10 | 4,342 |
TPS and stop screw set up | kazi | 7 | 8,643 |
04-23-2017 09:40 PM Last Post: kazi |
AE86 Engine Coolant Temp Sensor | izanagi | 8 | 20,296 |
09-06-2014 05:47 PM Last Post: izanagi |
Hall sensor | totta Crolla | 7 | 8,253 |
02-28-2014 10:07 AM Last Post: Ivan141 |
How to adjust the idle speed on your Toyota 4A-GE motor | Homem Bomba | 1 | 4,462 |
06-30-2013 01:08 PM Last Post: Homem Bomba |
