WATER IN MY HACHI?!?!
11-13-2007, 04:30 PM
hi folks,
i got a real problem... i got water in my hachi ...and i dont know where the water comes in?!?! i dont know what to do?!?! its behind the driver seat: (sorry for that baaad quality) ![]() ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., http://www.sideways.co.at ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., |
11-13-2007, 04:46 PM
2 possibilities. Door or rear window.
I would look for the 2nd option here. because with the age, the glass glue tends to weak and open some holes in it. ![]() Cump´s Filipe Oliveira |
11-13-2007, 04:49 PM
door is impossible... its dry like the sahara...
but the rear window..... ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., http://www.sideways.co.at ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., |
11-13-2007, 05:58 PM
Vielleicht ein rostloch in der Bodenplatte unterhalb der teermatten oder so...
11-14-2007, 10:04 PM
The rear windows often leak on aged ae86's.. just to make sure though, do you have a sunroof? That would be suspect nr 1 offcourse.
If the rear windows are the culprit...remove the rear seatcushion and have a look there too, since the water has to pass through there to come down. FABRICA MI DIEM, PVNC! |
11-14-2007, 10:22 PM
I would say sunroof aswell mine had water in the same spot.
No Smorking AE86 |
11-14-2007, 10:52 PM
Hi there,
i would suggest to check 3 options. Does your car has any rust? If yes then check your rear wheel domes to see if they are rusty or cracked. Mines are and the water comes inside on rainy days as the wheel turns. I found this because my car is stripped from the front seats towards the back. Second would be the rear windows as the other people said. And third check the center column of your car also known as pilar ( i don't remember A or B). Lift the door rubbers (weatherstrip) and seei if there is any rust or holes. Mine has some rust and i see water coming inside and going down from the safety belt place. Take a look at my car ![]() Toyota Corolla KE30 + Toyota Corolla AE86 |
11-15-2007, 02:05 PM
thanks fpr the answers!!
its not the window... and i got no sunroof!!! but i´ll look at the rear-dome! thanks!!!! ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., http://www.sideways.co.at ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., |
Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 7,563 |
12-06-2017 06:48 PM Last Post: Bean |
20v conversion water relocation | izanagi | 1 | 5,422 |
06-15-2016 09:45 AM Last Post: banpei |
20v with 16v Water Relocation Kit | D.O | 9 | 15,855 |
06-12-2014 02:48 AM Last Post: jondee86 |
water pump issues | Alex170984 | 24 | 23,584 |
08-27-2013 02:40 PM Last Post: Alex170984 |
Water in- & outlet 4agze ae101 | bozu | 5 | 11,198 |
08-14-2013 12:24 AM Last Post: jondee86 |
