Weak Grounding problem with Temperature sensor
07-29-2005, 12:25 AM
Hi Guys,
Was finally told the reason to the problem with my temp sensor not working. The sensor does not have a good ground!! If I touch a wire on the sender, and connect it with the negative terminal of the battery, the gauge will work. Can anyone tell me why my ground is bad? What should I look for to fix this without soldering a wire to the sensor and running it to the battery? Thanks for your help Trueno for sale! |
07-29-2005, 07:51 AM
You could try finding the ground wire that is originally connected to it and check where that goes. It's probably a loose contact somewhere. But the easiest thing to do would be to solder a wire with one of those crimp contacts that you can mount under a screw, and then attach that to a screw behind the dash going straight into a solid piece of chassis. (around the fuseboxes for example, or just use one of the grounds there.)
Lambda sensor wiring | sam3007 | 10 | 4,622 |
Weak spark, doesn’t start. | AlexFourTwenty | 4 | 15,505 |
Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 7,699 |
12-06-2017 06:48 PM Last Post: Bean |
Wheel Bearing Temperature | Super86 | 5 | 6,807 |
09-29-2014 12:26 AM Last Post: jondee86 |
AE86 Engine Coolant Temp Sensor | izanagi | 8 | 20,496 |
09-06-2014 05:47 PM Last Post: izanagi |
