What brakes are you using ?
06-25-2005, 12:06 PM
Pictures of the EG6 kit, 25,000 Yen
[Image: AEU86 AE86 - What brakes are you using ?]
06-27-2005, 12:56 PM
I have just ordered a set of Mintex 1155,
Have any of You tried this?
regards,
Skassa
"""www.turbotoys.dk"""
06-27-2005, 02:13 PM
Skassa,
Whats the difference between 1144 and 1155? Or is that a type?
How much where they and where did you order them?
06-27-2005, 02:22 PM
1144 is designed for road,light race
1155 is designed for rally trackdays. not good when cold
1166 is designed for pure race and will not work cold
I hope i can use them as a everyday pad,but i will see,it was just if others had tried them ,and had some comments to them.
I ordered them here in Denmark at a local grosist,and the price is around 70euro
Skassa
06-27-2005, 02:35 PM
Not to bad..
I am thinking of getting 1144s but not sure where I should order them...
06-27-2005, 05:44 PM
I just want some, that doesnt squeek and squirl... Its really annoying Angry
Any suggestions? I need som new pads for the front pretty soon, as a MOT is in the near future Confused
06-27-2005, 06:22 PM
Use coppergrease on the back of the pads...I havent heard my brakes squeel in a long time myself..
07-22-2005, 09:53 AM
Do any of you know how wide a disc,that can be used with the OE caliper?
There are some c-class disc ,that are 285x22.and they are easy to redrill,becourse the MB holes are drilled on a 105mm pcd
And i wonder if it can fit the 22mm instead of the 18mm ,is there room for it?
Regards,
Skassa
07-22-2005, 10:00 AM
Denmark Wrote:Do any of you know how wide a disc,that can be used with the OE caliper?
Regards,
Skassa
AFAIK you could use AE92 front disc with stock AE86 caliper (238mm).
Measure the central hole of your c-class discs - if the hole is over ~65mm - they are not applicable (you must redrill them to 4X85 PCD and 12mm holes for studs will be very close to the central hole - that's why I fail using BMW 728i discs).
07-22-2005, 10:16 AM
the hole in the c-class discs are 67mm.Yes it will be close ,but there are no force in that direction,so i don´t think it will be a problem
I wan´t to have the discs bigger for better cooling,that´s why i wount use the AE92 discs
Skassa
  Rear brakes totta Crolla 0 893 02-03-2023 12:54 PM
Last Post: totta Crolla
  Switching diffs for disc brakes? trippin 6 2,506 07-08-2022 03:35 AM
Last Post: trippin
  What suspension set up are people using? kazi 8 8,009 07-06-2017 05:26 AM
Last Post: headrush
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,744 12-21-2016 09:37 PM
Last Post: bozu
  Using a different diff in an AE86 megabob 6 8,161 02-17-2015 03:37 PM
Last Post: megabob
