What camshafts would be nice?
08-22-2010, 02:31 PM
Post: #31
do you have any idea how much those bucket lifters cost?
catcams springs and retainers were both around 125 euro's... that's EX. VAT '87 levin coupé ![]() |
08-22-2010, 03:53 PM
Post: #32
I am making ~150hp on these 7105137 260° 252° catcams. But they only really starts pulling above 5000rpm. I am running CR ~10,7 which could be better for these cams. Remember that you cannot exploit aggressive cams without a high CR.
08-22-2010, 04:01 PM
Post: #33
harkes Wrote:I am making ~150hp on these 7105137 260° 252° catcams. But they only really starts pulling above 5000rpm. I am running CR ~10,7 which could be better for these cams. Remember that you cannot exploit aggressive cams without a high CR. something with your intake/exhaust and or head is off then as you should produce good power earlier.. AE86 ex-daily |
08-22-2010, 04:03 PM
Post: #34
you do have cheaper and good options... as mentioned before there are still TRD springs available which work with the lift and OEM retainers cost around 10$each, catcams are 8€ each if I remember right... and lifters you can get a set from Passracing for 168$ or so but as mentioned before you better measure right and don't need to adjust later on 'cause you can't. or go for those arrow lifters
AE86 ex-daily |
08-22-2010, 08:40 PM
Post: #35
PatrickAE86 Wrote:do you have any idea how much those bucket lifters cost? I think 1NZFE lifters cost more than 15 euros each (240 euros for 16) |
08-22-2010, 09:13 PM
Post: #36
Bean Bandit Wrote:you can get a set from Passracing for 168$ or soActualy it's 268$ SEE HERE |
08-22-2010, 10:06 PM
Post: #37
whatever still rather cheap compared to straight european Toyota dealer price
![]() AE86 ex-daily |
08-23-2010, 09:21 PM
Post: #38
Plus freight and taxes don´t think so
08-23-2010, 10:15 PM
Post: #39
oh well I'm spoiled as I don't pay taxes
08-24-2010, 12:40 AM
Post: #40
PatrickAE86 Wrote:Hey there, First.... the BS in this thread is OVERWHELMING... second... DON'T believe ANYTHING without a dyno sheet to back it up! third... names mean nothing! ABOVE is my opinion..... BELOW are JUST FACTS!! 4AGE - smallport head with proper and precise porting. intake bowl... ![]() exhaust bowl... ![]() exhaust port as it leaves the head... ![]() 10.75 to 1 measured compression ratio(included the gap between the piston and cylinder wall, down to the first ring) stock Euro pistons, with the combustion chambers lowered to 33cc - this was done by having the head cut along with the porting above ![]() ![]() Web Camshafts... compare these to many of the "264" type camshafts with similar duration when measured @ .050" - 226 degrees ![]() 145hp and 112#/ft of torque measured @ the wheels. Numbers measured @ the crankshaft would be about 170hp and 134#/ft of torque. These #s are a bit low, since the cams will make power to 8400 rpm. Right now I have it LIMITED to 7500 The powerband is in excess of 4500 rpm (from 3000 rpm to 7500) ![]() Oh... the only non stock mechanical parts are valve springs - TRD type. Wrist pins - lightened aftermarket type and the camshafts and timing pulleys. The crank, rods, pistons, rings, valves are all standard Toyota parts Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
How would/have you rebuild your 4age? | joaotcgt | 6 | 9,932 |
07-21-2015 10:40 AM Last Post: mad.matt |
4AGE camshafts (again) | Alex170984 | 26 | 32,448 |
03-19-2013 02:41 PM Last Post: Alex170984 |
what clutch would you recommend | megabob | 12 | 12,489 |
02-22-2010 03:36 PM Last Post: NoHachi |
4age bogs. Would like some help! | root | 4 | 6,402 |
12-30-2009 11:10 AM Last Post: Nomuken |
9.5mm lift camshafts with OEM followers... anyone? | apardal | 9 | 9,975 |
10-15-2008 03:24 PM Last Post: robokill |
