What camshafts would be nice?
08-22-2010, 02:31 PM
Post: #31
do you have any idea how much those bucket lifters cost?
catcams springs and retainers were both around 125 euro's...
that's EX. VAT
'87 levin coupé
[Image: AEU86 AE86 - What camshafts would be nice?]
08-22-2010, 03:53 PM
Post: #32
I am making ~150hp on these 7105137 260° 252° catcams. But they only really starts pulling above 5000rpm. I am running CR ~10,7 which could be better for these cams. Remember that you cannot exploit aggressive cams without a high CR.
08-22-2010, 04:01 PM
Post: #33
harkes Wrote:I am making ~150hp on these 7105137 260° 252° catcams. But they only really starts pulling above 5000rpm. I am running CR ~10,7 which could be better for these cams. Remember that you cannot exploit aggressive cams without a high CR.
something with your intake/exhaust and or head is off then as you should produce good power earlier..
08-22-2010, 04:03 PM
Post: #34
you do have cheaper and good options... as mentioned before there are still TRD springs available which work with the lift and OEM retainers cost around 10$each, catcams are 8€ each if I remember right... and lifters you can get a set from Passracing for 168$ or so but as mentioned before you better measure right and don't need to adjust later on 'cause you can't. or go for those arrow lifters
08-22-2010, 08:40 PM
Post: #35
PatrickAE86 Wrote:do you have any idea how much those bucket lifters cost?
that's EX. VAT
I think 1NZFE lifters cost more than 15 euros each (240 euros for 16)
08-22-2010, 09:13 PM
Post: #36
Bean Bandit Wrote:you can get a set from Passracing for 168$ or so
Actualy it's 268$ SEE HERE
08-22-2010, 10:06 PM
Post: #37
whatever still rather cheap compared to straight european Toyota dealer price Wink
08-23-2010, 09:21 PM
Post: #38
Plus freight and taxes don´t think so Confused
08-23-2010, 10:15 PM
Post: #39
oh well I'm spoiled as I don't pay taxes Wink
08-24-2010, 12:40 AM
Post: #40
PatrickAE86 Wrote:Hey there,
I'm (re) building my 4a-ge and i want to put some other camshafts in it.
but what kind of cams would be good?
i'm going to incrase the compression ratio and do some headwork + itb setup.
what cams would be good for this one? i know about changing the valve train..
but what duration/lift?... idle and normal street driving kept in mind please Wink
thanks in advance
First.... the BS in this thread is OVERWHELMING...
second... DON'T believe ANYTHING without a dyno sheet to back it up!
third... names mean nothing!
ABOVE is my opinion..... BELOW are JUST FACTS!!
4AGE - smallport head with proper and precise porting.
intake bowl...
exhaust bowl...
exhaust port as it leaves the head...
10.75 to 1 measured compression ratio(included the gap between the piston and cylinder wall, down to the first ring) stock Euro pistons, with the combustion chambers lowered to 33cc - this was done by having the head cut along with the porting above
Web Camshafts... compare these to many of the "264" type camshafts with similar duration when measured @ .050" - 226 degrees
145hp and 112#/ft of torque measured @ the wheels. Numbers measured @ the crankshaft would be about 170hp and 134#/ft of torque. These #s are a bit low, since the cams will make power to 8400 rpm. Right now I have it LIMITED to 7500 The powerband is in excess of 4500 rpm (from 3000 rpm to 7500)
Oh... the only non stock mechanical parts are valve springs - TRD type. Wrist pins - lightened aftermarket type and the camshafts and timing pulleys. The crank, rods, pistons, rings, valves are all standard Toyota parts
Dan -
  How would/have you rebuild your 4age? joaotcgt 6 8,859 07-21-2015 10:40 AM
  4AGE camshafts (again) Alex170984 26 29,202 03-19-2013 02:41 PM
Last Post: Alex170984
  what clutch would you recommend megabob 12 10,825 02-22-2010 03:36 PM
Last Post: NoHachi
  4age bogs. Would like some help! root 4 5,760 12-30-2009 11:10 AM
Last Post: Nomuken
  9.5mm lift camshafts with OEM followers... anyone? apardal 9 8,959 10-15-2008 03:24 PM
Last Post: robokill
