What do you think about this High-throttle pulley?
02-05-2005, 09:43 AM
![]() Quote:The accelerator paddle's travel is reduced to provide an improved acceleration response. A slight foot pressure applied on the paddle will result in a swift acceleration response! Does anyone understand this? Is this item a smaller pulley causing quicker response? or is it a larger pulley? And what other car's throttle pulley can we use to make this? |
02-05-2005, 09:48 AM
Its a smaller pulley, cuz a smaller one has shorter travel then a larger. You know, the circels diameter is reduced...
02-05-2005, 09:50 AM
Notice that the car will be "more difficult" to drive, as youll give more gas with the same amount of force to the paddle :wink:
Thats what I thought. Now how can you modify the stock pully to make it do this?
02-05-2005, 09:55 AM
Im sure it would be much easyer to buy one thats already made. I dont think its possible to modify the stock... Have a look at a scrapyard, perhaps you will be lucky to find something that could be used instead.
High-beam warning lamp | Mylesmck | 4 | 1,763 |
Engine stress at high speeds | gh0st | 6 | 2,876 |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 23,486 |
Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) | Rascal21 | 41 | 36,540 |
08-21-2016 04:51 PM Last Post: ray |
Headlights - only high beam working | Jezza_hr | 3 | 7,641 |
01-10-2015 11:59 AM Last Post: jondee86 |
