What do you think about this High-throttle pulley?
02-05-2005, 09:43 AM
[Image: AEU86 AE86 - What do you think about thi...le pulley?]
Quote:The accelerator paddle's travel is reduced to provide an improved acceleration response. A slight foot pressure applied on the paddle will result in a swift acceleration response!
Does anyone understand this? Is this item a smaller pulley causing quicker response? or is it a larger pulley? And what other car's throttle pulley can we use to make this?
02-05-2005, 09:48 AM
Its a smaller pulley, cuz a smaller one has shorter travel then a larger. You know, the circels diameter is reduced...
02-05-2005, 09:50 AM
Notice that the car will be "more difficult" to drive, as youll give more gas with the same amount of force to the paddle :wink:
Thats what I thought. Now how can you modify the stock pully to make it do this?
02-05-2005, 09:55 AM
Im sure it would be much easyer to buy one thats already made. I dont think its possible to modify the stock... Have a look at a scrapyard, perhaps you will be lucky to find something that could be used instead.
  High-beam warning lamp Mylesmck 4 1,572 07-21-2023 07:44 AM
  Engine stress at high speeds gh0st 6 2,653 08-30-2022 07:11 PM
Last Post: Power_uP
  4AGE 16V engine overheat when at high speed chenfon 32 22,173 12-31-2020 06:39 AM
Last Post: chenfon
  Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) Rascal21 41 34,442 08-21-2016 04:51 PM
Last Post: ray
  Headlights - only high beam working Jezza_hr 3 7,495 01-10-2015 11:59 AM
Last Post: jondee86
