What is Error code 51 in the GZE?
02-04-2011, 07:07 AM
Hi guys,
I'm seeing the error code 51 in my GZE.
51
Switch signals: TPS idle switch off; neutral start switch off (automatic transmission in Drive); A/C switch on; A/C switch/circuit; A/C amplifier; TPS/circuit; neutral start switch/circuit; ECU
The net says the above mentioned points but can anyone tell me whether I can test these myself in the car?
thanks alot,
Heshan.
Cheated on my いたずらな女の子 and now I can't get enough of her..
02-04-2011, 07:47 AM
tps is easy to test. You can find the correct values to adjust tsp.. So that i look first!
02-06-2011, 02:28 PM
Thanks Corolla..
I searched but I couldn't find the default setting..
Do you know? Does anyone have a diagram or a How-To on this?
02-06-2011, 03:05 PM
http://www.ae92gts.com/ae92gts_tps.html
I think i did adjust mine 4agze whit that and is OK
do you got Aircon at car? etc?
02-06-2011, 08:09 PM
yes got aircon.. why?
Got power steeringSmile which is becoming a pain as my mechanic deviced a way to to couple the old unit from my GE.. Sad
02-06-2011, 08:36 PM
Just think that there is TPS and aircon errors what may be the case..
02-14-2011, 03:40 AM
I still haven't found the problem yet. Lets see..
Just getting the car out from my mechanic. Lets see how the condition is.
I changed the Fuel filter, did an injector clean up and also changed the water pump..
Filled up SuperCharger with oil!! Old mechanic had left empty!!!! Used A/C Compressor oil. lets see how its going to handle
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 7,310 11-09-2020 10:51 AM
Last Post: totta Crolla
  DLI GZE no spark 4agetercel 5 7,084 02-01-2013 07:05 PM
Last Post: 4agetercel
  GZE Swop with PAS & AC Lauren 12 13,829 02-16-2012 01:04 PM
Last Post: heshan
  Engine sounds slush GZE with VIDEO ! Okami 13 14,575 01-03-2012 12:12 PM
Last Post: Okami
  GZE swap in a SR5 TomTom15 3 4,344 11-04-2011 12:30 PM
Last Post: MatthewG
