What is the axle. T293
11-25-2009, 05:20 PM
i dont know if tercel one will fit also, i want to convert my ke70 this is how the pedalbox have to look like:
12-11-2009, 12:28 AM
For your information, that LSD is exactly the same as the AE86 item. The whole axle should be the same as AE86. Except AE86 had the 4.3:1 ratio.
12-11-2009, 12:00 PM
Jonny Rochester Wrote:For your information, that LSD is exactly the same as the AE86 item. The whole axle should be the same as AE86. Except .
And how it might affect the possibilities of running my AE70?
My gear ratio 4.1:1 compared with AE86 4.3:1 ratio!?
[Image: AEU86 AE86 - What is the axle. T293]
http://ae70.blogspot.com/ & http://drft.io.ua/
  AE86 rear axle weight megabob 11 19,598 03-29-2024 11:18 AM
Last Post: FanIsHere
  Axle width totta Crolla 1 1,302 10-24-2023 12:20 PM
  Rear axle options Dino86 13 13,634 01-08-2018 10:19 PM
Last Post: ditn
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,920 12-21-2016 09:37 PM
Last Post: bozu
  wider rear axle,track width,suspension questions ditn 6 9,265 10-18-2016 11:50 AM
Last Post: fantapants
