What is the axle. T293
11-25-2009, 05:20 PM
i dont know if tercel one will fit also, i want to convert my ke70 this is how the pedalbox have to look like:
12-11-2009, 12:28 AM
For your information, that LSD is exactly the same as the AE86 item. The whole axle should be the same as AE86. Except AE86 had the 4.3:1 ratio.
12-11-2009, 12:00 PM
Jonny Rochester Wrote:For your information, that LSD is exactly the same as the AE86 item. The whole axle should be the same as AE86. Except . And how it might affect the possibilities of running my AE70? My gear ratio 4.1:1 compared with AE86 4.3:1 ratio!? http://ae70.blogspot.com/ & http://drft.io.ua/ |
AE86 rear axle weight | megabob | 11 | 18,521 |
Axle width | totta Crolla | 1 | 1,003 |
Rear axle options | Dino86 | 13 | 12,704 |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,750 |
wider rear axle,track width,suspension questions | ditn | 6 | 8,513 |
