What is this part...
06-26-2014, 10:23 PM
(This post was last modified: 06-26-2014 10:31 PM by izanagi.)
Hi all.
Someone could tell me why i've this spacer (blue-green part) at the starter ? Thanks. I ask that because i can't start my car. The small wheel of the start doesn't engage the flywheel. It always hit the front of the flywheel. Maybe this part is the problem. |
06-27-2014, 01:11 AM
(06-26-2014 10:23 PM)izanagi Wrote: Hi all.it looks like a spacer but not original. not sure if somebody messed around with a different starter and needed it to make it work. Sent from my Nexus 4 using Tapatalk AE86 ex-daily |
06-27-2014, 01:14 AM
(This post was last modified: 06-27-2014 01:16 AM by jondee86.)
Looks like a 1g starter adapter...
Quote:Allows the use of 1G series high torque starter motors on 4AGE/4AGZE Cheers... jondee86 |
06-27-2014, 06:45 AM
(This post was last modified: 06-27-2014 06:46 AM by izanagi.)
(06-27-2014 01:14 AM)jondee86 Wrote: Looks like a 1g starter adapter... Thanks. That's it. Now my second problem is that the crownwheel of the starter hit the front of the flywheel each time i try to start. It doesn't engage the flywheel. But when I start with start cables with another car that is running, the car start everytime. Possible that is my battery ??? Envoyé depuis mon GT-I9100 avec Tapatalk (06-27-2014 01:14 AM)jondee86 Wrote: Looks like a 1g starter adapter... Thanks. That's it. Now my second problem is that the crownwheel of the starter hit the front of the flywheel each time i try to start. It doesn't engage the flywheel. But when I start with start cables with another car that is running, the car start everytime. Possible that is my battery ??? Envoyé depuis mon GT-I9100 avec Tapatalk |
06-27-2014, 08:41 AM
Possible yes, depending on the condition of the starter it might need a good cleaning to move freely again.
06-27-2014, 08:49 AM
(06-27-2014 06:45 AM)izanagi Wrote: Possible that is my battery ??? Seems that the voltage at the starter is a bit low. Check the battery voltage after the car has been sitting overnight. If it is less than 12V then the battery might be getting tired. If it is 12.5V or better, the battery is good. Then you need to check/clean the battery terminal connections, and earth strap connections from engine to chassis and from chassis to battery. Cheers... jondee86 |
06-27-2014, 04:56 PM
What would be the best brand and type for a new battery ?
06-27-2014, 07:12 PM
(06-27-2014 04:56 PM)izanagi Wrote: What would be the best brand and type for a new battery ? http://www.braillebattery.co.uk/ honestly just get what is available for a reasonable price with a decent amp rating. AE86 ex-daily |
06-28-2014, 04:04 AM
(06-27-2014 07:12 PM)Bean Bandit Wrote:(06-27-2014 04:56 PM)izanagi Wrote: What would be the best brand and type for a new battery ? Which model should i buy ? Envoyé depuis mon GT-I9100 avec Tapatalk |
06-28-2014, 09:18 AM
Seriously just go down to your local store and buy what ever they have in mid price range and around 60amp (45minimum).
No need for a Braille unless you're taking part in very serious racing competitions or money is no issue because you earn/got more than plenty of it. Sent from my Nexus 4 using Tapatalk AE86 ex-daily |
User(s) browsing this thread: 20 Guest(s)
