What is this part...
06-26-2014, 10:23 PM (This post was last modified: 06-26-2014 10:31 PM by izanagi.)
Hi all.
Someone could tell me why i've this spacer (blue-green part) at the starter ?
Thanks.
[Image: AEU86 AE86 - What is this part...]
I ask that because i can't start my car. The small wheel of the start doesn't engage the flywheel. It always hit the front of the flywheel. Maybe this part is the problem.
06-27-2014, 01:11 AM
(06-26-2014 10:23 PM)izanagi Wrote:  Hi all.
Thanks.
it looks like a spacer but not original. not sure if somebody messed around with a different starter and needed it to make it work.
Sent from my Nexus 4 using Tapatalk
AE86 ex-daily
06-27-2014, 01:14 AM (This post was last modified: 06-27-2014 01:16 AM by jondee86.)
Looks like a 1g starter adapter...
Quote:Allows the use of 1G series high torque starter motors on 4AGE/4AGZE
RWD engines using K-50, T-50 or W55 (with Niteparts bellhousing) gearboxes.
Cheers... jondee86
06-27-2014, 06:45 AM (This post was last modified: 06-27-2014 06:46 AM by izanagi.)
(06-27-2014 01:14 AM)jondee86 Wrote:  Looks like a 1g starter adapter...
Cheers... jondee86
Thanks. That's it.
Now my second problem is that the crownwheel of the starter hit the front of the flywheel each time i try to start. It doesn't engage the flywheel.
But when I start with start cables with another car that is running, the car start everytime.
Possible that is my battery ???
Envoyé depuis mon GT-I9100 avec Tapatalk
Cheers... jondee86
Thanks. That's it.
06-27-2014, 08:41 AM
Possible yes, depending on the condition of the starter it might need a good cleaning to move freely again.
AE86 ex-daily
06-27-2014, 08:49 AM
(06-27-2014 06:45 AM)izanagi Wrote:  Possible that is my battery ???
Seems that the voltage at the starter is a bit low. Check the battery
voltage after the car has been sitting overnight. If it is less than 12V
then the battery might be getting tired. If it is 12.5V or better, the
battery is good. Then you need to check/clean the battery terminal
connections, and earth strap connections from engine to chassis and
from chassis to battery.
Cheers... jondee86
06-27-2014, 04:56 PM
What would be the best brand and type for a new battery ?
06-27-2014, 07:12 PM
(06-27-2014 04:56 PM)izanagi Wrote:  What would be the best brand and type for a new battery ?
http://www.braillebattery.co.uk/
honestly just get what is available for a reasonable price with a decent amp rating.
AE86 ex-daily
06-28-2014, 04:04 AM
Which model should i buy ?
06-28-2014, 09:18 AM
Seriously just go down to your local store and buy what ever they have in mid price range and around 60amp (45minimum).
No need for a Braille unless you're taking part in very serious racing competitions or money is no issue because you earn/got more than plenty of it.
AE86 ex-daily
