What radiator to use??
06-02-2007, 06:19 AM
Hi. Put a hole in my AE85's radiator today, took it out and realised how small it is. Eventually I will have a 16v 4age of some description in there so I figure ill change it now.
What radiators are good to use?
What are you guys using?
06-02-2007, 08:37 AM
VW Golf or AE86s own
06-02-2007, 09:34 AM
A radiator from a first generation RX7 is supposed to be a near direct fit for the Hachi and twice the thickness of a stock AE86 one.
06-02-2007, 02:44 PM
I need new one too soon, mine still leak... Sad
06-02-2007, 04:48 PM
i went all out and got a koyo full aluminum race radiator, thats just me though, got it off of ebay
Slide to side worldwide!!
[Image: AEU86 AE86 - What radiator to use??]
06-02-2007, 06:21 PM
i bought Nissens replacement ae86 oem radiator for around 100 euros here new.
06-02-2007, 08:11 PM
I used a radiator from a camry v6
it's big enough with 2 electrical fans
I had some problems with the cooling with the stock radiator and the mechanical fan...
06-02-2007, 10:44 PM
I would love a koyo one! Very nice indeed? Might explore the Camry option or see if I can put in a core twice the size (thickness) but still use the AE85 end tanks. That way I can keep the TRD radiator cap.
06-02-2007, 11:10 PM
I will probably settle on a Koyo myself. Although I have read that a Toyota Hiace radiator is a good 3 core option and ideal if you're planning a GZE conversion.
06-03-2007, 12:05 AM
Hey David, how about introducing yourself properly here on the forums. You've been participating for a while now and seem to have a pretty cool hachi. I'm sure everyone here is interested in you and your ae86, I am for starters Smile
  Radiator & grill support panel (Levin) FanIsHere 5 3,701 11-14-2022 10:07 PM
  Alu thick core radiator fitment Gtsi-R 5 4,484 01-26-2022 01:28 PM
Last Post: Gtsi-R
  AE86 F20C swap - Radiator issue mad.matt 3 7,302 02-07-2018 05:14 PM
  Radiator oem or upgrade on racecar? Jimmi The Kid 5 7,260 06-23-2017 05:21 PM
Last Post: pack
  cool lower radiator hose thanos 4 6,988 11-29-2016 01:06 PM
Last Post: thanos
