What radiator to use??
06-02-2007, 06:19 AM
Hi. Put a hole in my AE85's radiator today, took it out and realised how small it is. Eventually I will have a 16v 4age of some description in there so I figure ill change it now.
What radiators are good to use? What are you guys using? |
06-02-2007, 08:37 AM
What radiator to use?? | |||
06-02-2007, 09:34 AM
A radiator from a first generation RX7 is supposed to be a near direct fit for the Hachi and twice the thickness of a stock AE86 one.
06-02-2007, 02:44 PM
I need new one too soon, mine still leak...
06-02-2007, 04:48 PM
i went all out and got a koyo full aluminum race radiator, thats just me though, got it off of ebay
Slide to side worldwide!! |
06-02-2007, 06:21 PM
i bought Nissens replacement ae86 oem radiator for around 100 euros here new.
06-02-2007, 08:11 PM
I used a radiator from a camry v6
it's big enough with 2 electrical fans I had some problems with the cooling with the stock radiator and the mechanical fan... |
06-02-2007, 10:44 PM
I would love a koyo one! Very nice indeed? Might explore the Camry option or see if I can put in a core twice the size (thickness) but still use the AE85 end tanks. That way I can keep the TRD radiator cap.
06-02-2007, 11:10 PM
I will probably settle on a Koyo myself. Although I have read that a Toyota Hiace radiator is a good 3 core option and ideal if you're planning a GZE conversion.
06-03-2007, 12:05 AM
Hey David, how about introducing yourself properly here on the forums. You've been participating for a while now and seem to have a pretty cool hachi. I'm sure everyone here is interested in you and your ae86, I am for starters
Radiator & grill support panel (Levin) | FanIsHere | 5 | 1,933 |
11-14-2022 10:07 PM Last Post: Ivan141 |
Alu thick core radiator fitment | Gtsi-R | 5 | 2,723 |
01-26-2022 01:28 PM Last Post: Gtsi-R |
AE86 F20C swap - Radiator issue | mad.matt | 3 | 5,819 |
02-07-2018 05:14 PM Last Post: mad.matt |
Radiator oem or upgrade on racecar? | Jimmi The Kid | 5 | 5,580 |
cool lower radiator hose | thanos | 4 | 5,304 |
