What radiator to use??
06-03-2007, 02:35 AM
my dad came with a question, would the original AE86 radiator work for the 20 valve silvertop?
06-03-2007, 04:47 PM
I too have the SV21 Camry twin core, see here:
http://www.ae86drivingclub.com.au/forum/...l=radiator
06-03-2007, 05:24 PM
evfan42 Wrote:my dad came with a question, would the original AE86 radiator work for the 20 valve silvertop?
Jup, it will.
06-03-2007, 11:07 PM
Little remark about the rx-7 SA radiators: they seem to need bigger diameter piping than the stock radiator, so fitting them is not nearly plug and play.
I would just opt for a new ae86 radiator.. it can handle regular use of a 4age very efficiently.
06-04-2007, 04:42 AM
Jup, it will.
alright thanks no hachi
06-05-2007, 09:47 PM
oldskull Wrote:I need new one too soon, mine still leak... Sad
Heey Oldskull!
Mijn radiator is ook zo lek als een zeef. Ik ben ga een dezer dagen naar een leverancier. Ik kan korting vragen als we samen bestellen?
EDIT: oeps dit moest een pm zijn Confused
[Image: AEU86 AE86 - What radiator to use??]
07-09-2007, 01:49 PM
Would a Mk2 Golf/Jetta radiator work??
07-09-2007, 06:11 PM
It has been done before...but it requires some fiddling with a pressure tank.
07-09-2007, 06:59 PM
hachirokuGTV Wrote:Would a Mk2 Golf/Jetta radiator work??
Yes, it would work
07-09-2007, 07:41 PM
It will but you have to either run the water lines across the back of the head or over the header and across the front of the head to get them to work. You can use an early 80's Corolla radiator that has both openings on the right side (when looking from the front of the engine bay) as opposed to the openings both on the left as with the original AE86 layout.
I have a Koyo in my car. It's OK. I'm currently having a high driving temperature, but I'm suspecting the thermostat to be the culprit. I'm working with Sym from Pass Racing on locating a low temp unit for me.
Peter Diaz
http://www.shiftgearclothing.com
http://www.ectoyotas.com/forum/
http://www.facebook.com/elfatherae86
  Radiator & grill support panel (Levin) FanIsHere 5 2,224 11-14-2022 10:07 PM
  Alu thick core radiator fitment Gtsi-R 5 3,080 01-26-2022 01:28 PM
Last Post: Gtsi-R
  AE86 F20C swap - Radiator issue mad.matt 3 6,048 02-07-2018 05:14 PM
  Radiator oem or upgrade on racecar? Jimmi The Kid 5 5,927 06-23-2017 05:21 PM
Last Post: pack
  cool lower radiator hose thanos 4 5,616 11-29-2016 01:06 PM
Last Post: thanos
