Whats the biggest cams for the 4AG?
04-14-2005, 01:59 PM
Sounds good to me ...why don't we start our own championship? Tongue
04-14-2005, 02:03 PM
Mmmmh, guys, offtopic !
Lets use this thread for big cams, ok ?
Pesonally if any modification is prohibited - I will stop under 270 cam. Maybe 264 (If I remember correctly). If the engine is lambda-sensored, the ECU can manage up to 10% corrections - I think.
04-17-2005, 02:49 PM
the 16v 4AGE isn't lamda sensored right. So How much can the MAP ECU correct. I know that if the engine is MAF then its like 10%
You have by far the ugliest hachi on the nicest rims in the world -Mux213
04-18-2005, 02:09 PM
Mulisha, some 16V 4AGE's are not lambda sensored.
Some are. Even on AE86.
04-18-2005, 02:41 PM
Weird, Why cant they make the engines all the same.
So 270 is the max that an ECU can handle it I have the 16v with MAP and no Lambda
04-20-2005, 12:42 PM
Had a set of cams in my hand the other day with an 11mm lift!!!!!!! animals
  Question about 4AG 20v Engine Block CHACAMAN 1 1,830 06-10-2022 05:17 PM
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,948 02-10-2020 06:39 PM
Last Post: Power_uP
  Shim size for AM cams kazi 4 5,414 12-18-2017 05:34 PM
  whats the crack with 16v turbo? kazi 5 6,563 08-02-2017 12:15 AM
Last Post: kazi
  Toda Cams Alex170984 7 8,978 02-11-2017 05:50 PM
Last Post: Alex170984
