Wheel alignment settings for the track
11-17-2016, 10:56 AM
Hi guys,
What wheel settings you are using for the track for your ae86?
I have been using ae86 for drifting mainly, so high camber was just fine. However now turning more to a circuit and I do get a feeling that the settings for the front wheel alignment may not be ideal for the track.
Would be great to hear what you think about this.
Thanks! Smile
11-17-2016, 11:00 AM
Depends on the track and tire type. I usualy used around 1.5 camber sometimes more, rarely less.
11-17-2016, 05:49 PM
1.5 Camber sounds good for a starting point....
Too bad we can't camber in the rear.... damn Smile
11-17-2016, 06:38 PM
Thanks! Will give it a go Smile
Talking about the rear it saves hell a lot of a headache, always look at the bright side.. Smile
11-17-2016, 07:33 PM
also consider about just a bit of toe out for better response and cornering, in expense of the straight line stability .
11-17-2016, 07:49 PM
Well... we have the rear Cusco RCA
[Image: AEU86 AE86 - Wheel alignment settings for the track]
Should improve something.... Smile
11-18-2016, 12:37 AM
A friend of mine uses this setting:
Long circuit:
Camber - 1.5
Toe - 0
Caster - 0
Short circuits:
Camber - 2
Toe - 0
Caster - 0
Jorda MotorSport
Keto Beams Project
11-18-2016, 08:45 AM
rallysetup testing
camber -1
toe 0
caster (4'30" normal due to rules)
11-18-2016, 10:41 PM
If your driving is halfway decent 1 to 1.5 degrees of negative camber will not be enough. If you take temps I'm guessing you'll end up somewhere 3 degrees plus. Probably more than 4.
The only way to know for sure is to either buy a tire pyrometer and take temps after sessions or to buy ultrasoft compound tires that wear down in one to two trackdays (and see if inner tire wear is in check).
For example, my miata on Rcomps needs 3 degrees negative with better camber curves than the AE86 ever came with. I'm thinking you'll need at least a degree static camber on top of that to overcome the McPherson handicap.
With that said, hitting the optimum is not that important. The car drives mostly fine with suboptimal settings, it just eats into the tire budget if its too far out of whack.
11-23-2016, 02:10 PM
Thanks guys for your advice! Seems that i will have to play with the settings a bit. Once the car is driven on different tracks and country roads there won't be one setting to fit all, but any way judging on what you have said there is definitely some space for improvement Smile
Tongue Trackday with my 86 at mornay track makkuro 2 5,073 04-27-2019 03:44 PM
Last Post: makkuro
  Grip/ Proffrsional Track Coilovers hachirokkos 15 19,726 10-15-2016 08:26 PM
Last Post: NoHachi
  AE-86 Track/Race car Spoiler/GT Wing Size and shape hachirokkos 5 11,334 11-26-2015 04:24 AM
Last Post: asyrigos
  Grobnik track day - AE86 inside ZaX 2 6,349 11-17-2011 02:57 PM
  Wheel Alignment for drift? zounds 6 10,561 03-25-2009 08:48 PM
Last Post: PazzaAE86
