Wheel stud specifications?
05-19-2013, 06:27 PM
Does anyone know the width/diameter/thread etc for the standard wheel studs? I'm looking to buy a set, but I've been told it's less costly to go through a third party supplier instead of Toyota direct.
05-19-2013, 08:48 PM
[Image: AEU86 AE86 - Wheel stud specifications?]
Thread: M12x1.5
Length: OEM are short, something like 45mm. But you can use longer one.
05-19-2013, 09:10 PM
Brilliant, thank you Thumbs up!
05-20-2013, 11:35 AM
The ones from a lexus ls200 are longer i believe
AE86 Levin
08-13-2013, 08:21 AM
Making use of this thread as the title is searchable Smile
I was researching this topic recently, as I scored some vintage
Watenabes for my AE86, and found the stock studs were not long
enough to get the proper number of turns on the wheel nuts. This
is what I found...
The only useful measurement is the length (measured from under
the head) as hub thickness and brake discs can affect the amount
of stud you can see.
All of these studs have the 14.17-14.20 knurl and will happily pull
into AE86 hubs without raising a sweat. A lot of the Toyota studs
are used on more than one vehicle, and may have "replaced by"
part numbers different from the original.
EDIT:
Toyota Part: 90942-02037 Replaced By: 90942-02049. Which means
the MR2, Previa, Prado, Hi-Lux, Lexus etc all use the same stud.
EDIT:
These also work... http://www.summitracing.com/parts/arp-100-7715
66 long with 14.17 knurl... you might have pull the axles to fit them.
Cheers... jondee86
  specifications for LSD rebuild H7ERO 53 56,199 04-11-2011 09:59 AM
Last Post: T_AE86
User(s) browsing this thread:
