Wheels, dimensions, offset and so on
10-27-2006, 04:41 AM
Quote:Where do you live btw? Cause you should check the junkyards for old Nissan, Mazda, Mitsubishi and Toyota rims, you might be able to find some with the needed parameters. I live in Narvik, in the northern Norway. I'll have a look around now that I have all the numbers down :-) |
10-27-2006, 08:32 AM
Good luck and feel free to ask for further informations.
11-04-2006, 06:25 AM
Seems it's impossible to find any 14" rims in norway with an offsett lower than +35.
I tried a set with +35 offset and it's like 0.5 mm from the spring so I don't think those will be such a good idea. So now I'm gonna order some 32 mm spacers from TechnoToyTuning, and that should clear things up ![]() Man it's no fun not being able drive my hachi now that the ground is covered with snow and ice. I just hope it won't take too long to get the spacers shipped from the U.S. |
11-04-2006, 11:29 AM
good luck man.
[offtopic]Anyway, Norway is a nice country. I am in Oslo last weekend. Such a lovely country I must say ![]() 1985 AE86 (ハチロク) Levin - Summer time daily driver |
11-04-2006, 12:15 PM
call http://www.sharif.no
Philip |
11-06-2006, 11:47 AM
amigaguy Wrote:Seems it's impossible to find any 14" rims in norway with an offsett lower than +35. You can get cheap 8mm spacers easily using old worn brake dics with 4X114mm pattern (for example - rear AE86 discs) and some lathe cutting work. T3 also sells cheap thin spacers. |
11-10-2006, 06:00 AM
Oh flarn... I just checked the date of my first post in this thread. It has already been over a month since my car was grounded... Unbelivable
![]() And still I haven't been able to come up with a solution. I tried mailing TechnoToyTuning about spacers, but he don't seem to be responding ATM. Found some on Ebay, but they seemed a bit expensive. Never thought that it would be such a problem finding a couple of rims that would fit. |
11-10-2006, 08:32 AM
Can't you let a local mechanist make the spacers for you?
11-10-2006, 10:33 AM
And btw you can make yourself spacers from old brake discs, cutting their middle. I can't make it without the proper tools but you might can or can find someone who make this for you.
11-10-2006, 04:47 PM
SutteR Wrote:Can't you let a local mechanist make the spacers for you? That'll be much more expensive. Prolly gonna take about 4 hours to make on a milling machine and that would run about $500. Well, that's what they told me at least. |
Quick question - Brake Pad Dimensions | Lt86 | 2 | 5,466 |
06-07-2015 12:08 AM Last Post: jondee86 |
Dimensions clutch master cylinder | bozu | 2 | 6,224 |
04-16-2015 07:11 AM Last Post: bozu |
Billet 5X114.3 hubs adds 30mm offset | 4000GT | 0 | 3,663 |
01-30-2015 06:40 AM Last Post: 4000GT |
Spindle dimensions, backing plate bolt pattern | Rascal21 | 18 | 22,146 |
03-13-2014 11:45 AM Last Post: Rascal21 |
DRAG dr54 wheels >> +15 offset >? help !! | geoscranny84 | 4 | 6,033 |
04-26-2012 09:31 PM Last Post: bozu |
