When do you need a FPR (Aftermarket)
06-21-2012, 04:34 PM
Hi guys,
I need to know with my 4agze with stock injectors (I guess)
if I need a aftermarket FPR??? (Fuel pressure regulator)
I have ordered a QSP 160 lph fuel pump as I am running a little bit more boost with the upgraded crankshaft pulley.
I think I am around 170bhp with the 1st gen 4agze (originally 145bhp)
So upgrading to that 160lph fuel pump should be a step in the right direction.
What else would I need? Or what could make it all run better... (to preserve the engine as i am also drifting etc.).
-DWG- Drift Wolf Gaming
06-21-2012, 04:42 PM
If you are not making any changes to:
- engine (cams, valves, pistons...)
- or map
- or injectors
you should not change FPR.
06-21-2012, 06:13 PM
Okay - in the future I will get 4age cams into the 4agze! Cheap upgrade!
and I will also buy better injectors as I will run more boost.
so only then I will probably need a FPR.
Thanks!
06-22-2012, 01:09 AM
Won´t need one for your current setup, but if you go get it mapped with the mods to come, a FPR comes handy for setting a the fuel pressure and maybe get that little bit extra fuel out of your injectors by running higher pressure.
Make sure you get one for turbo/ SC cars as you need the rising fuel pressure with rising boost pressure.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
06-22-2012, 11:16 PM
Thanks! Will try to keep that all in mind!
  Aftermarket / Additional Foglights decryphe 6 10,481 07-08-2017 08:45 AM
  wiring aftermarket tachomete izanagi 7 10,370 05-21-2014 08:15 PM
  Has anyone used an aftermarket coil like MSD blaster? JDMitch 6 9,841 09-06-2010 06:14 PM
Last Post: Red
  Aftermarket Cams, IDLE issue. kool mints 12 13,931 07-11-2009 12:04 AM
Last Post: kool mints
  Need some help to mount aftermarket semi bucket set oldskull 4 5,294 06-23-2008 10:40 PM
Last Post: Bubble_Drift
