When do you need a FPR (Aftermarket)
06-21-2012, 04:34 PM
Hi guys,
I need to know with my 4agze with stock injectors (I guess) if I need a aftermarket FPR??? (Fuel pressure regulator) I have ordered a QSP 160 lph fuel pump as I am running a little bit more boost with the upgraded crankshaft pulley. I think I am around 170bhp with the 1st gen 4agze (originally 145bhp) So upgrading to that 160lph fuel pump should be a step in the right direction. What else would I need? Or what could make it all run better... (to preserve the engine as i am also drifting etc.). -DWG- Drift Wolf Gaming |
06-21-2012, 04:42 PM
If you are not making any changes to:
- engine (cams, valves, pistons...) - or map - or injectors you should not change FPR. |
06-21-2012, 06:13 PM
Okay - in the future I will get 4age cams into the 4agze! Cheap upgrade!
and I will also buy better injectors as I will run more boost. so only then I will probably need a FPR. Thanks! -DWG- Drift Wolf Gaming |
06-22-2012, 01:09 AM
Won´t need one for your current setup, but if you go get it mapped with the mods to come, a FPR comes handy for setting a the fuel pressure and maybe get that little bit extra fuel out of your injectors by running higher pressure.
Make sure you get one for turbo/ SC cars as you need the rising fuel pressure with rising boost pressure. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
06-22-2012, 11:16 PM
Thanks! Will try to keep that all in mind!
Aftermarket / Additional Foglights | decryphe | 6 | 9,704 |
07-08-2017 08:45 AM Last Post: banpei |
wiring aftermarket tachomete | izanagi | 7 | 9,679 |
05-21-2014 08:15 PM Last Post: banpei |
Has anyone used an aftermarket coil like MSD blaster? | JDMitch | 6 | 9,158 |
09-06-2010 06:14 PM Last Post: Red |
Aftermarket Cams, IDLE issue. | kool mints | 12 | 13,091 |
07-11-2009 12:04 AM Last Post: kool mints |
Need some help to mount aftermarket semi bucket set | oldskull | 4 | 4,933 |
06-23-2008 10:40 PM Last Post: Bubble_Drift |
