Where to get inserts for coilovers?
05-21-2011, 01:50 PM
Im looking for front shock inserts for a set of coilovers im building, im looking for something cheap, maybe mr2 or ae92 inserts?
Has anyone got a link to where i can buy them pref in europe. Also what springs should i be using and wheres the best place to buy? Thanks |
05-22-2011, 01:01 PM
Springs depend on the size of coilover you're using.
Rally design has some pretty cheap springs, but the sizing is all for metric coilovers. Dunno if the 60mm ones will fit the 2.5 inch coilover most people seem to use (ground control). Otherwise you can get inch sized springs for a bit more money at merlin motorsport: http://www.merlinmotorsport.co.uk/COILOV...c5f5ceefba As far as shocks are concerned: ae92 is pretty short, but will fit (if you go shortstroke!). You can have a look around ebay.de to see if you can find any bargains (doesnt happen often though). Since you need to ask I'm guessing you're probably not really a german ![]() If you need to choose, skimp on the springs and buy the best shocks you can find. I like Bilstein myself, but Koni is easier to find. FABRICA MI DIEM, PVNC! |
06-02-2011, 12:57 AM
dFaulkner for springs,raldes for springs and perches, you're fucked for shocks. Everything very expensive, best to just pony up and buy the best you can find the first time round. HTS or Koni's
Carina drivers! - Coilovers for a TA60/62 | nyberrg | 2 | 6,602 |
06-05-2017 10:03 AM Last Post: nyberrg |
Fitting driftworks CS2 coilovers | bozu | 2 | 4,959 |
05-30-2017 10:50 AM Last Post: bozu |
D2 Coilovers any good? | heshan | 18 | 27,382 |
04-04-2017 02:40 AM Last Post: hachirokkos |
Has anyone tried BC Racing coilovers? | AlexKTM | 9 | 12,516 |
09-05-2016 12:28 PM Last Post: mad.matt |
Anyone running DIY Coilovers? | Rasteirinho | 8 | 14,110 |
11-19-2013 10:30 PM Last Post: totta Crolla |
