Which engine/tranny mounts???
07-30-2008, 01:00 PM
Does anyone have experience with different kinds of these mounts?
Mine are worn out so I need new ones. Robokill tried the Cusco ones, they are alot stiffer than standard items, which is nice. But there is also a drawback, they send massive vibrations through the car, I know this is inherent to stiffer materials but I want something in between the standard and Cusco ones. Are the TRD mounts a solution perhaps? Any info and experiences are welcom. ![]() Aram. |
08-01-2008, 07:10 PM
cusco lowers the engine and gearbox a little, which is good for your center of gravity. Stock mounts shoulc do fine, but if the car is used for track, then vibrations are not a big concern.
08-02-2008, 10:50 AM
revolver and also techno spirit pro do similar items
08-05-2008, 01:28 PM
Quote:cusco lowers the engine and gearbox a little, which is good for your center of gravity. Stock mounts shoulc do fine, but if the car is used for track, then vibrations are not a big concern. Very marginal though - side by side maybe 2/3 mm between them - cant see it making any difference? ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
08-05-2008, 04:21 PM
havent seen the actual items myself.. it is a lot of weight so lower is always better. But I doubt you'd notice 2-3mm indeed.
08-05-2008, 07:22 PM
Techno pro spririt = 10mm lower
08-12-2008, 06:03 AM
The TRD mounts are the ones to get because stock or generic replacements costs just as much and are not as hard, durometer.
20v BT - which oil pump? | Mylesmck | 4 | 3,069 |
Lets talk engine mounts | kazi | 6 | 8,137 |
08-31-2017 12:46 PM Last Post: parrot |
Rim width. Which is best.... | Dino86 | 5 | 7,031 |
which connector is this | ditn | 7 | 8,066 |
07-27-2015 11:24 AM Last Post: pack |
Haslbeck front spoiler, which foglights? | wouter86 | 2 | 5,240 |
02-15-2015 11:14 AM Last Post: ditn |
