Which engine/tranny mounts???
07-30-2008, 01:00 PM
Does anyone have experience with different kinds of these mounts?
Mine are worn out so I need new ones.
Robokill tried the Cusco ones, they are alot stiffer than standard items, which is nice.
But there is also a drawback, they send massive vibrations through the car, I know this is inherent to stiffer materials but I want something in between the standard and Cusco ones.
Are the TRD mounts a solution perhaps?
Any info and experiences are welcom. Thumbs up!
Aram.
08-01-2008, 07:10 PM
cusco lowers the engine and gearbox a little, which is good for your center of gravity. Stock mounts shoulc do fine, but if the car is used for track, then vibrations are not a big concern.
08-02-2008, 10:50 AM
revolver and also techno spirit pro do similar items
08-05-2008, 01:28 PM
Quote:cusco lowers the engine and gearbox a little, which is good for your center of gravity. Stock mounts shoulc do fine, but if the car is used for track, then vibrations are not a big concern.
Very marginal though - side by side maybe 2/3 mm between them - cant see it making any difference?
[Image: AEU86 AE86 - Which engine/tranny mounts???]
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
08-05-2008, 04:21 PM
havent seen the actual items myself.. it is a lot of weight so lower is always better. But I doubt you'd notice 2-3mm indeed.
08-05-2008, 07:22 PM
Techno pro spririt = 10mm lower
08-12-2008, 06:03 AM
The TRD mounts are the ones to get because stock or generic replacements costs just as much and are not as hard, durometer.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  20v BT - which oil pump? Mylesmck 4 2,615 06-21-2022 04:51 PM
Last Post: pack
  Lets talk engine mounts kazi 6 7,640 08-31-2017 12:46 PM
Last Post: parrot
  Rim width. Which is best.... Dino86 5 6,706 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 7,549 07-27-2015 11:24 AM
Last Post: pack
  Haslbeck front spoiler, which foglights? wouter86 2 4,986 02-15-2015 11:14 AM
Last Post: ditn
